Summit XL mobile platform by Robotnik
Post links to your Youtube videos related to CoppeliaSim
mabemon
Post by mabemon » 10 Apr 2014, 10:04
Summit XL mobile platform by Robotnik in a video about V-REP simulation made by researchers of Robotic Group of Ai2 (UPV).
http://www.youtube.com/watch?v=SkGAlIh7 ... 0oqALvRLOp
N_rob
Re: Summit XL mobile platform by Robotnik
Post by N_rob » 21 Apr 2014, 11:17
Hi I am working on the simulation of the Summit Xl on V Rep. I saw this video and I want to know the steps done in order to have this model working as on the video. Thank you
Post by coppelia » 22 Apr 2014, 21:18
the video was done by user mabemon, that you may contact to obtain the model. But as far as I know the model is currently still quite approximate (i.e. the vehicle is a single rigid entity, no spring/damping in the wheel arms).
N_rob
Post by N_rob » 07 Jun 2014, 20:09
I want to ask about the PID control in the dynamic properties of joints. What do we use them for exactly? I mean what do they
affect?
Thank you
Post by coppelia » 09 Jun 2014, 10:04
the PID controller is usually used to control a joint in position (i.e. if you need to keep the joint follow a desired position). Most of the time, only the P component of the PID is used.
amattag
Contact:
Post by amattag » 09 Jun 2014, 10:15
I am also working with the Summit XL mobile platform at Universidad Politécnica de Madrid.
Is there a way that you can share your model with us?
Thank you very much.
Antonio Matta.
Post by coppelia » 09 Jun 2014, 10:22
Hello Antonio,
if you contact us here, we can put you in touch with the person in charge.
N_rob
Post by N_rob » 10 Jun 2014, 08:27
Thank you for the answer but I would like to know what does the derivate position do to the joint performance?
I have one more thing please, I am doing frction essays on V Rep with the Summit XL model, with both Billet and ODE, and I am wondering why the robot cannot climb more than 33 degrees almost whereas the real robot can go up to 45 degree slope.
Thank you very much
Post by coppelia » 10 Jun 2014, 11:38
Have a look at how a PID controller works.
Then, your simulation in the mentioned situation will only be as good as the model and the used physics engine. A physics engine will never compute exact results, actually they are quite approximate. And you can always adjust the friction parameters of the wheels or the ground.
