simExtOMPL_setValidStateSamplerCallback not working as intended
e2718
Post by e2718 »
I believe the function simExtOMPL_setValidStateSamplerCallback is not working as intended. I think the callback functions (args 2 and 3) are not being set and you can put in invalid function names and still get a return code of 1 instead of the failure code of 0. Below is how I've tested this and came to this conclusion.
Have been working on a simple scene to do some 3d path planning with two spheres and a bar in the middle. The goal of this scene is have two modes of path planning. The first is when the sphere runs along the ground, and the other one with the default 3d path planning (so the sphere can float above the step)
download link for the scene is at https://www.dropbox.com/s/z7sgbfpe0zfz1 ... t.ttt?dl=0
Image of the scene is at https://www.dropbox.com/s/8weziqakni9vb ... t.png?dl=0
In the script in start_config, I have the following lines of interest
    -- skipping some lines
    ground_samplers = true  -- whether or not to use the custom sampler functions
    -- set the custom sampling params
    if ground_samplers then
        r = simExtOMPL_setValidStateSamplerCallback(t, 'ground_sampler', 'ground_near_sampler')
        --r = simExtOMPL_setValidStateSamplerCallback(t, 'foo', 'bar')  -- also works with fake function names
        print('----------------------')
        print("ground sampler set with result: " .. r)
When run this scene I get the output:
ground sampler set with result: 1
I also get the same print result if I un-comment the line
Which makes me suspect that the simExtOMPL_setValidStateSamplerCallback function does not actually check to see if the function name arguments are valid and also does not set those functions as the callback ones.
Re: simExtOMPL_setValidStateSamplerCallback not working as intended
The function is working as intended: it will set the specified stateSampler callbacks.
You can use simOMPL.printTaskInfo() to verify that the callbacks are set.
You are expecting for it to validate the given functions names, but this is not meant to happen.
If V-REP in future will have a way for validating those kind of arguments, maybe this will change.
Currently, if you set an incorrect callback name, this will result in an error later, when simCallScriptFunctionEx() is called by the planner, but will not result in an error in setValidStateSamplerCallback().
e2718
Post by e2718 »
Ok, have started changed the child script in start_config to use simExtOMPL_printTaskInfo and it seems like something is wrong with the callback and callbackNear variables.
I have a script that calls OMPL 3d path planning with a custom sampler (to sampler all states where z=ground_height). The code that calls simExtOMPL_printTaskInfo is here
        simExtOMPL_printTaskInfo(t)
The output of this is:
OMPL: task name: task
OMPL: state spaces: (dimension: 7)
OMPL:     state space: 9003
OMPL:         name: 3d
OMPL:         type: sim_ompl_statespacetype_pose3d
OMPL:         object handle: 19
OMPL:         bounds low: {-2, -2, 0.05}
OMPL:         bounds high: {2, 2, 1.05}
OMPL:         default projection: true
OMPL:         weight: 1
OMPL: collision pairs: {17, -2}
OMPL: start state: {}
OMPL: goal:
OMPL:     goal state(s):
OMPL: state validation: default
OMPL: state validity checking resolution: 0.01
OMPL: valid state sampling:
OMPL:     callback:
OMPL:         scriptId: 2050009
OMPL:         function: ground_sampler
OMPL:     callbackNear:
OMPL:         function: ground_near_sampler
OMPL: projection evaluation: default
OMPL: algorithm: sim_ompl_algorithm_RRTConnect
From the task info, it appears the relevant samplers have been set. However, when I call simExtOMPL_solve it appears that it does not call the callback and callbackNear functions specified in the task info (the heights of the states are not ground_height=0.05). The code that calls simExtOMPL_solve is here:
    -- r, path=simExtOMPL_compute(t, 8, -1, 100)
    simExtOMPL_setup(t)
    if simExtOMPL_solve(t, 8) then
        --simExtOMPL_simplifyPath(t)  -- not simplifying path to test the sampler
        simExtOMPL_interpolatePath(t, 100)
        r,path = simExtOMPL_getPath(t)
For reference the entire child script is here:
-- DO NOT WRITE CODE OUTSIDE OF THE if-then-end SECTIONS BELOW!! (unless the code is a function definition)
visualizePath=function(path)
    if not _lineContainer then
        _lineContainer=simAddDrawingObject(sim_drawing_lines,3,0,-1,99999,{0.2,0.2,0.2})
    simAddDrawingObjectItem(_lineContainer,nil)
    if path then
        local pc=#path/7
        for i=1,pc-1,1 do
            lineDat={path[(i-1)*7+1],path[(i-1)*7+2],path[(i-1)*7+3],path[i*7+1],path[i*7+2],path[i*7+3]}
            simAddDrawingObjectItem(_lineContainer,lineDat)
-- given a limits of {min_x, max_x, min_y, max_y, min_z, max_z}
-- picks a random point in the unit box
randomPointBox=function(lower_limits, upper_limits)
    min_x, min_y, min_z = lower_limits
    max_x, max_y, max_z = upper_limits
    x_val = min_x + math.random() * (max_x - min_x)
    y_val = min_y + math.random() * (max_y - min_y)
    z_val = min_z + math.random() * (max_z - min_z)
    return {x_val, y_val, z_val}
-- given a center point (x, y), will pick a random point in the circle of given radius
-- algorithm from http://mathworld.wolfram.com/DiskPointPicking.html
randomPointCircle=function(center, radius)
    u = math.random()
    v = math.random() * 2 * math.pi
    x_val = center[1] + (radius * math.sqrt(u) * math.cos(v))
    y_val = center[2] + (radius * math.sqrt(u) * math.sin(v))
    return {x_val, y_val}
ground_sampler=function()
    print("ground_sampler")
    min_x, min_y, _ = lower_limits
    max_x, max_y, _ = upper_limits
    x_val = min_x + (max_x - min_x) * math.random()
    y_val = min_y + (max_y - min_y) * math.random()
    -- use default orientation of (0, 0, 0, 1)
    return {x_val, y_val, ground_height, 0.0, 0.0, 0.0, 1.0}
ground_near_sampler=function(state, distance)
    print("ground_near_sampler")
    sampled_point = randomPointCircle({state[1], state[2]}, distance)
    while sampled_point[1] < min_x or sampled_point[1] > max_x or sampled_point[2] < min_y or sampled_point > max_y do
    return {sampled_point[1], sampled_point[2], ground_height, 0.0, 0.0, 0.0, 1.0}
    -- Put some initialization code here
    -- Make sure you read the section on "Accessing general-type objects programmatically"
    -- For instance, if you wish to retrieve the handle of a scene object, use following instruction:
    -- handle=simGetObjectHandle('sceneObjectName')
    -- Above instruction retrieves the handle of 'sceneObjectName' if this script's name has no '#' in it
    -- If this script's name contains a '#' (e.g. 'someName#4'), then above instruction retrieves the handle of object 'sceneObjectName#4'
    -- This mechanism of handle retrieval is very convenient, since you don't need to adjust any code when a model is duplicated!
    -- So if the script's name (or rather the name of the object associated with this script) is:
    -- 'someName', then the handle of 'sceneObjectName' is retrieved
    -- 'someName#0', then the handle of 'sceneObjectName#0' is retrieved
    -- 'someName#1', then the handle of 'sceneObjectName#1' is retrieved
    -- If you always want to retrieve the same object's handle, no matter what, specify its full name, including a '#':
    -- handle=simGetObjectHandle('sceneObjectName#') always retrieves the handle of object 'sceneObjectName'
    -- handle=simGetObjectHandle('sceneObjectName#0') always retrieves the handle of object 'sceneObjectName#0'
    -- handle=simGetObjectHandle('sceneObjectName#1') always retrieves the handle of object 'sceneObjectName#1'
    -- Refer also to simGetCollisionhandle, simGetDistanceHandle, simGetIkGroupHandle, etc.
    -- Following 2 instructions might also be useful: simGetNameSuffix and simSetNameSuffix
    lower_limits = {-2, -2, 0.05}
    upper_limits = {2, 2, 1.05}
    ground_height = 0.05 -- default ground height
    -- path finding code
    start_handle=simGetObjectHandle('start_config')
    goal_handle=simGetObjectHandle('goal_config')
    t=simExtOMPL_createTask('task')
    ss={simExtOMPL_createStateSpace('3d', sim_ompl_statespacetype_pose3d, start_handle, lower_limits, upper_limits, 1)}
    simExtOMPL_setStateSpace(t, ss)
    simExtOMPL_setAlgorithm(t, sim_ompl_algorithm_RRTConnect)
    collision_pairs={simGetObjectHandle('start'), sim_handle_all}
    simExtOMPL_setCollisionPairs(t, collision_pairs)
    start_pos=simGetObjectPosition(start_handle, -1)
    start_orient=simGetObjectQuaternion(start_handle, -1)
    start_pose={start_pos[1], start_pos[2], start_pos[3], start_orient[1], start_orient[2], start_orient[3], start_orient[4]}
    simExtOMPL_setStartState(t, start_pose)
    goal_pos=simGetObjectPosition(goal_handle, -1)
    goal_orient=simGetObjectQuaternion(goal_handle, -1)
    goal_pose={goal_pos[1], goal_pos[2], goal_pos[3], goal_orient[1], goal_orient[2], goal_orient[3], goal_orient[4]}
    simExtOMPL_setGoalState(t, goal_pose)
    simExtOMPL_setup(t)
    pathLen = #path/7
    pathIndex = 1
    print('path info')
    print('result code: ' .. r)
    print('path length: ' .. (#path/7))
    print('script handle: ' .. (simGetScriptHandle('start_config')))
    -- Put your main ACTUATION code here
    -- For example:
    -- local position=simGetObjectPosition(handle,-1)
    -- position[1]=position[1]+0.001
    -- simSetObjectPosition(handle,-1,position)
    if pathIndex == pathLen - 1 then
        pathIndex = 1
        pathIndex = pathIndex + 1
    i = pathIndex * 7 + 1
    pos={path[i],path[i+1],path[i+2]}
    orient={path[i+3],path[i+4],path[i+5],path[i+6]}
    simSetObjectPosition(start_handle,-1,pos)
    simSetObjectQuaternion(start_handle,-1,orient)
    visualizePath(path)
    -- Put your main SENSING code here
    -- Put some restoration code here
e2718
Post by e2718 »
Forgot to mention this, but also have put in print statements into the sampler calls, and it appears that the functions are not being called (none of the print statements appear in the console).
Code for the sampler functions
    print("ground_sampler called")
    print("ground_near_sampler called")
e2718
Post by e2718 »
Bumping this thread because no reply in 5 days to the update on the bug
I'm not an expert with OMPL, but even with the StateSampling demo of OMPL, using RRTConnect does not call the valid state sampler, so you might have to choose an appropriate algorithm (the demo uses PRM).
additionally, if you are running on Windows, it might be not working in any case. Try with the latest V3.5.0 beta.
e2718
Post by e2718 »
Update:
This is a bit late, but thanks for the help. Turns out that the path planners do not call the same random samplers. Only some of them will call the custom sampler algorithms.
