In file included from sourceCode/interfaces/v_rep.cpp:30:0:
sourceCode/interfaces/v_rep.h:34:33: fatal error: v_rep_funcUndefines.h : No such file or directory
Can you help me?
BTW : I'm on Ubuntu 12.04 with Qt5.1.1 and QScintilla2.8
you are right, the last release has a few problems. You can comment the line that includes v_rep_funcUndefines.h. Probably a few similar occurences.
That happens, because the source code went through a preprocessing stage, that stripped it from many things that are not needed. This should slowly be removed with time, until the source code will be put to a public repository.
The version you have is slightly different from the master version, for various practical and historical reasons.
In your case, rename _prepareCustomGuiEvent_noDirectEventProccessing to _prepareCustomGuiEvent_noDirectEventProcessing. Then you should almost be there. We'll try to put an updated version of the source code online within 1-2 days.
