Transformation Matrix ROS Publisher
formica
Post by formica »
I'm trying to enable a ros publisher to stream the transformation matrix (wrt the world frame) of an object.
Unfortunately, the publisher does not appear...
TransformationMatrixPub=simExtROS_enablePublisher('RWTF',1,simros_strmcmd_get_transform,Object,-1,'')
Any idea?
Re: Transformation Matrix ROS Publisher
this is not a bug, but how the tf broadcaster works.
Type for instance:
$ rosrun tf tf_echo /objectName /world
and you will see what the publisher sends.
