I can't run V-REP
I can't run V-REP
I installed V-REP PRO EDU, but when I tried to launch it, I saw the message: "Error: could not find or correctly load v_rep.dll". Then this window closed after pressing Enter.
But this v_rep.dll is in the root directory of program. I tried to reinstall V-REP, but nothing was changed.
What can I do to launch program?
Re: I can't run V-REP
what Windows version do you have? And what V-REP version?
Hello!
Windows XP SP3 and V-REP PRO EDU version.
Hi again,
I am at a loss here. Do you have the same problems with the PLAYER version?
Can you try to check for missing dependencies with dependency walker for example?
I have the same problem with V-REP PLAYER.
There are two problems in dependency walker: (when I launch vrep.exe)
But I copied V_PER from other computer in which it successfully launched (with Windows 7) to USB-flash and it successfully launched on this computer from USB-flash.
Oh, I launched the program from USB-flash and now it works without any problems even if I start V-REP (which I installed few days before) from my computer!
Thanks for your help!
I installed V-REP PRO EDU, but when I tried to launch it, I saw the message: "V-REP stopped working". Then windows closed.
. I tried to reinstall V-REP , but nothing was changed.
what V-REP are you using? What is your platform? How do you start V-REP? Did a previous V-REP version run fine?
Hello, I'm using V-REP PRO EDU V3.1.2 for windows, is the first version that i installed, I tried with double click and also I tried with the console in administrator mode, I have windows 7.
Can you do following:
- in the V-REP installation folder, open system/usrset.txt and turn on all the debug flags (at the top of the file).
- then start V-REP and send us the debugLog.txt file (in the same folder)
