Bounding Boxes and Vision Sensor
JohnnyMudcrab
Post by JohnnyMudcrab »
not really a bug, but confusing as i think. When selecting a vision sensor, the bounding box will be its clipping plane. Which is convenient. The bounding box of a model surrounds all bounding boxes of its parts. So if you have a model with a wide range vision sensor the bounding box will be enormous, which can be quite confusing. In my opinion i would be better to exclude the bounding boxes of vision sensors for determining the size of model bounding boxes.
best regards
Re: Bounding Boxes and Vision Sensor
to avoid that problem, you can for the vision sensor (or any other object) check the Don't show as inside model selection item in the object common properties.
JohnnyMudcrab
Awesome! Thanks a lot!
cheers
