If I try to remotely control the robot from Matlab (R2013b x64) using Remote API (remoteApi.so for 64-bits) connection is successfully stablished and handles to the joints return a valid number, even I can start and stop the simulation properly in synchronous mode. However, I am having troubles with simxSetJointTargetPostion function, because the simulation ignores it and the joint doesn't change its target position. I have also tried non-synchronous modes, a simulation witout dynamic contens (joints configured in passive mode) and the funcion simxSetJointPosition instead of simxSetJointTargetPosition, but the result is the same, the call is simply ignored. The return error code is 1, which I think is normal if a call the functions with simx_opmode_oneshot.
I post here my code:
vrep=remApi('remoteApi');
vrep.simxFinish(-1); % just in case, close all opened connections
clientID=vrep.simxStart('127.0.0.1',19997,true,true,5000,5);
try
if (clientID>-1)
vrep.simxSynchronous(clientID,1); %%Enables synchronous mode
vrep.simxStartSimulation(clientID,vrep.simx_opmode_oneshot);
qLID=zeros(12,1);
for i=1:6
str=sprintf('%s%d','joint',i);
[~,qLID(i)]=vrep.simxGetObjectHandle(clientID,str,vrep.simx_opmode_oneshot_wait);
for i=1:6
str=sprintf('%s%d','joint',13-i);
[~,qLID(i+6)]=vrep.simxGetObjectHandle(clientID,str,vrep.simx_opmode_oneshot_wait);
qL=zeros(12,1);
for i=1:12
qL(i)=30*pi/180;
%Now run the simulation a given number of iterations
for k=1:30
vrep.simxPauseCommunication(clientID,1);
for i=1:length(qL)
ret=vrep.simxSetJointTargetPosition(clientID,qLID(i),qL(i),vrep.simx_opmode_oneshot);
vrep.simxPauseCommunication(clientID,0);
vrep.simxSynchronousTrigger(clientID);
vrep.simxStopSimulation(clientID,vrep.simx_opmode_oneshot);
pause(1);
vrep.simxFinish(clientID);
disp('Failed connecting to remote API server');
vrep.delete(); % call the destructor!
catch err
vrep.simxFinish(clientID); % close the line if still open
end;
disp('Program ended');
The output I get is:
Running Matlab glnxa64
make sure you use the corresponding remoteApi library
(i.e. 32bit Matlab will not work with 64bit remoteApi, and vice-versa)
Program ended
Variable qLID is:
qLID =
56
57
58
59
60
61
67
66
65
64
63
62
