MatLab crashing
kleinash
MatLab crashing
Post by kleinash » 08 Dec 2014, 11:54
I am having trouble with either MatLab or VREP or both crashing and having to restart.. Is there a way to check crash reports / log errors and send them through to you for analysis?
Regards
kleinash
Re: MatLab crashing
Post by kleinash » 08 Dec 2014, 14:46
There are a few issues - and I re-downloaded V-REP to make sure that I was on the latest version.
1. When V-REP starts it freezes a bit and I cannot move my mouse to past the top or bottom of the GUI
2. I then have to ALT+T to get to another screen, which seams to unfreeze V-REP
3. I head to my remote API MatLab set up and open the server communication
4. I run my program and it crashes MatLab (sometimes, but more often than not lately)
5. As my V-REP program has not completed I head over to the simulator and hit stop button
6. Re-start MatLab and server - if I get a successful run then MatLab provides me with the answers I need - but V-REP freezes and I have to hard shut down the gui (end task) - if it doesn't happen the first run it happens the second
Any thoughts?
Regards
Re: MatLab and VREP crashing
Post by coppelia » 08 Dec 2014, 22:34
Hello Ashley,
on what platform are you? Are you using the remote API synchronous mode? Did the problem exist since long, or did it happen only recently (e.g. after you modified something)?
kleinash
Post by kleinash » 09 Dec 2014, 14:48
I have two machines the one that has the problem is Windows 7, MatLab is 2013b
If I run exaclty the same code on my Linux machine I do not have the problem.. ie everything runs (a little slower because its a smaller machine - but it runs no problems). Ubuntu 12.04, MatLab 2012a
I think I am running synchronous, I have changed allot - but not with the connectivity and that doesnt explain why it would work on one machine and not the other.
Rgds
Post by coppelia » 10 Dec 2014, 00:15
Can you check at what point Matlab crashes? I guess it crashes after a specific instruction.
Also, make sure to use the Matlab remote API components from the last V-REP release (i.e. it is not good to mix the remote API client components with a different version of V-REP).
kleinash
Re: MatLab crashing
Post by kleinash » 27 Jan 2015, 09:46
It crashes when I run this from the remote API:
res = vrep.simxSetUIButtonProperty(h.id, h.UIhandle, 20, vrep.sim_buttonproperty_isdown, vrep.simx_opmode_oneshot);
I use this to close the barrett hand from within V-REP
I made sure these where correct:
remoteApiProto.m
remApi.m
remoteApi.dll
Was really hoping that was the issue.. but unfortunately it still crashes.. and it seams to crash on my Linux machine too now.
EDIT: I fixed it :) Instead of using the button property to close and open the hand, I set an integer signal for the child script to read. i.e.
MatLab:
res = vrep.simxSetIntegerSignal(h.id , 'closing', 0, vrep.simx_opmode_oneshot )
Child script:
closing=simSetIntegerSignal("closing", signalValue)
and to open again from MatLab:
res = vrep.simxSetIntegerSignal(h.id , 'closing', 1, vrep.simx_opmode_oneshot )
EDIT2: but now I cant get it to open again.. Previously I set the button down and then reopened but just rolling the button up - but now I dont have that option.. and I cannot see an easy way of opening the hand again.
Re: MatLab crashing
Post by coppelia » 27 Jan 2015, 20:13
Ashley,
can you tell me what crashes (V-REP, Matlab, both?), or if the Matlab program is simply causing an error. In that case what error is output?
kleinash
Re: MatLab crashing
Post by kleinash » 28 Jan 2015, 11:19
So this morning its all back to crashing again - even with the changes I made. And I cannot get the closing/opening signal to register..
first issue:
Only matlab crashes.
Second issue:
I use this to close the barrett hand:
res = vrep.simxSetIntegerSignal(h.id , 'closing',1 , vrep.simx_opmode_oneshot );
and this to open it:
I run it once - it closes at the right time but does not open.
I then restart everything and its as if VREP remembers that it was closing and just carries on - even when I just run the simulation from within VREP.
I need it to start and not close - and then close when I tell it to and open when I tell it to.
I printed the signal from within VREP and it does flip - but at odd times - and then I changed the timing signals - but that too does not work..
My error is somewhere in this script - at least if I take this area out then it does not crash.. and if I run it a couple times it is able to clear the closing signal - then I add this in and it crashes and sets the closing signal in and outside VREP.
%% ===== grasp object
   % child script: closing=simGetIntegerSignal("closing")
   pause(3)
   %% ==== test grasp by removing box
   grasp_measure = test_grasp(h, vrep, pos_relative, object_position);
   % if grasp was successful then read hand position postion
   if grasp_measure
        for i = 1:6
            [res, bhand_fingerJoints(i, 1:3)]= vrep.simxGetObjectPosition(h.id, h.fingerJoints(i), pos_relative, vrep.simx_opmode_buffer);
        db_output.bhand_closed = bhand_fingerJoints;
        % replace box
        vrep.simxSetObjectPosition(h.id , h.box, -1, box_pos, vrep.simx_opmode_oneshot);
        pause(2)
        %% open hand again
        pause(2)
        % change spread position for hand and re-test grasp
        for spr = 0:200:1000
           spread = spr;
           db_output.spread = spread;
           res = vrep.simxSetUISlider(h.id, h.UIhandle, 21, spread, vrep.simx_opmode_oneshot);
% close the hand and repeat
           pause(1)
        %% stop the simulation if unsuccessful
        res = vrep.simxStopSimulation(h.id, vrep.simx_opmode_oneshot)
Eric
Re: MatLab crashing
Post by Eric » 28 Jan 2015, 12:36
Hi
Are you cleaning the signal v-rep side, after you received a signal different than nil?
something like:
res=simGetIntegerSignal('closing')
if res~=nil then
  simClearIntegerSignal('closing')
  if res==1 then
     --closing code
     --opening code
cheers
Eric
ps: not sure why you use
in you child script... maybe you are confused with simGetIntegerSignal?
kleinash
Re: MatLab crashing
Post by kleinash » 28 Jan 2015, 14:24
Here is the total script from the child:
	if (closing) then
        print("closing is true")
	elseif not (closing) then
        print("closing is false")
	if res~=nil then
		if res==1 then
		for i=1,3,1 do
		if (closing)and(needFullOpening[1]~=2)and(needFullOpening[2]~=2)and(needFullOpening[3]~=2) then
			if (firstPartLocked[i]) then
				simSetJointTargetVelocity(jointHandles[i][3],closingVel/3)
				t=simJointGetForce(firstPartTorqueSensorHandles[i])
				if (t)and(t<-firstPartMaxTorque) then
					firstPartTorqueOvershootCount[i]=firstPartTorqueOvershootCount[i]+1
					firstPartTorqueOvershootCount[i]=0
				if (firstPartTorqueOvershootCount[i]>=firstPartTorqueOvershootCountRequired) then
					needFullOpening[i]=1
					firstPartLocked[i]=true
					-- First joint is now locked and holding the position:
					simSetObjectIntParameter(jointHandles[i][2],2001,1)
					simSetJointForce(jointHandles[i][2],closingOpeningTorque*100)
					simSetJointTargetPosition(jointHandles[i][2],simGetJointPosition(jointHandles[i][2]))
					-- second joint is now not in position control anymore:
					simSetObjectIntParameter(jointHandles[i][3],2001,0)
					simSetJointTargetVelocity(jointHandles[i][2],closingVel)
					simSetJointTargetPosition(jointHandles[i][3],(45*math.pi/180)+simGetJointPosition(jointHandles[i][2])/3)
			if (needFullOpening[i]==1) then
				needFullOpening[i]=2
			simSetJointTargetVelocity(jointHandles[i][3],openingVel/3)
				jv=simGetJointPosition(jointHandles[i][3])
				if (jv<45.5*math.pi/180) then
					firstPartLocked[i]=false -- we unlock the first part
					simSetObjectIntParameter(jointHandles[i][2],2001,0)
					simSetJointForce(jointHandles[i][2],closingOpeningTorque)
					simSetJointTargetVelocity(jointHandles[i][2],openingVel)
				if (needFullOpening[i]~=0) then
					jv3=simGetJointPosition(jointHandles[i][3])
					jv2=simGetJointPosition(jointHandles[i][2])
					if (jv3<45.5*math.pi/180)and(jv2<0.5*math.pi/180) then
						needFullOpening[i]=0
						-- second joint is now again in position control:
						simSetObjectIntParameter(jointHandles[i][3],2001,1)
I just pasted where I think that code you put in should go..
I set closing by:
and opening by:
I do say simGetIntegerSignal("closing") rather than the Set one - that was a previous mistake that I hadnt cleaned in the comments.
Your solution solved the closing issue - but I still can't get it to open..
I deleted the hand and reimported another one which seamed to help
and it hasnt crashed since I made this change - but I thought I had fixed that yesterday..
