el_Raimundo
Post
by el_Raimundo » 29 Mar 2015, 23:31
Hello there,
I'm using vrep 3.2.0 (rev6) and I believe there's a wrong argument type specified in Line 119 in the vrep Python remote API source code. Here's the original:
c_SetStringSignal = CFUNCTYPE(c_int32,c_int32, POINTER(c_char), POINTER(c_ubyte), c_int32, c_int32)(("simxSetStringSignal", libsimx))
where it should actually be POINTER(c_char) two times, for signal name as well as signal value, like this:
c_SetStringSignal = CFUNCTYPE(c_int32,c_int32, POINTER(c_char), POINTER(c_char) , c_int32, c_int32)(("simxSetStringSignal", libsimx))
no?
Posts: 10366 Joined: 14 Dec 2012, 00:25
Post
by coppelia » 30 Mar 2015, 13:53
the signal name is a regular string, i.e. chars, but cannot contain embedded zeros.
The string signal value is a buffer of random values (i.e. bytes), which can also contain embedded zeros. In some languages, strings can also contain embedded zeros, and in that case, there is hardly a difference with a regular string.
el_Raimundo
Post
by el_Raimundo » 30 Mar 2015, 19:12
I see,
but if I leave the argument type mentioned above at POINTER(c_ubyte) the python interpreter complains:
File "/Applications/V-REP_PRO_EDU_V3_2_0_Mac/programming/remoteApiBindings/python/python/vrep.py", line 929, in simxSetStringSignal
return c_SetStringSignal(clientID, signalName, signalValue, len(signalValue), operationMode)
ctypes.ArgumentError: argument 3: <type 'exceptions.TypeError'>: expected LP_c_ubyte instance instead of str
the following minimal python program will create this error:
import vrep
if __name__ == '__main__':
clientID = vrep.simxStart('127.0.0.1', 19997, True, True, 500, 5)
vrep.simxSetStringSignal(clientID, 'some signal name', 'some signal value', vrep.simx_opmode_oneshot)
changing it to POINTER(c_char) resolves this, but I'm not sure if this is a valid fix.
Post
by coppelia » 30 Mar 2015, 20:09
If you want to use a string as signal value, do something like:
import ctypes
str_bytes = 'some signal value'
raw_ubytes = (ctypes.c_ubyte * len(str_bytes)).from_buffer_copy(str_bytes)
vrep.simxSetStringSignal(clientID, 'some signal name', raw_ubytes, vrep.simx_opmode_oneshot)
With Python3 is would be like:
import ctypes
str_bytes = b'some signal value'
vrep.simxSetStringSignal(clientID,b'some signal name', raw_ubytes, vrep.simx_opmode_oneshot)
el_Raimundo
Post
by el_Raimundo » 30 Mar 2015, 20:44
thanks, it executes fine now.
I was not aware that this conversion was neccessary.
