video problem
edgarbangkok
video problem
Post by edgarbangkok »
I installed the beta V-REP
3.2.1 BETA)
Unfortunately I always have the problem when i use menus
https://vimeo.com/126024139
despite having changed pc (see attached video)
I am using windows 7 64 bit video card with updated drivers
my card:
Operating System: Windows 7 Ultimate, 64-bit (Service Pack 1)
DirectX version: 11.0
GPU processor: GeForce GTX 745
Driver version: 347.88
Direct3D API version: 11
Direct3D feature level: 11_0
CUDA Cores: 384
Core Clock Speed: 1032 MHz
Memory data rate: 1800 MHz
Memory interface: 128-bit
Memory bandwidth: 28.80 GB / s
Total available graphics memory: 11991 MB
Dedicated video memory: 4096 MB DDR3
System video memory: 0 MB
Shared system memory: 7895 MB
Video BIOS version: 82.07.32.40.51
IRQ: 16
Bus: PCI Express x16 Gen3
The same problems also I have on another pc w7 64bit and ATI card
edgar from bangkok
Re: video problem
Hello Edgar,
I cannot play your video somehow..
What version did you previously use?
edgarbangkok
Re: video problem
the problem and 'started the version of v-rep. 3.0.5
See the previous post
'A small display problem
PostBy edgarbangkok »27 Oct 2013, 03:28
A small display problem with new versions of v-rep. 3.0.5 '
Before I used a PC with a video card AMD Radeon HD 7350 and updated drivers for windows 7
Now I bought a new pc with w7 and video card NVIDIA GeForce GTX 745 but the problem remains the same even with the latest beta vrep
I am using
I send the video by email
edgar
Re: video problem
The problem appears rarely, and is probably directly linked to Qt/the OS/the GPU driver.
I noticed you are running V-REP in a sandbox, this could also have an effect.
Also, some virtual boxes also make sometimes small display problems.
The best you can do is try to update the graphic card drivers, and maybe also change the OS display setting (try with a minimal setting, i.e. no fancy effects, etc.).
