import stl
markusi
import stl
Post by markusi » 30 Apr 2013, 08:39
When importing an stl (without recentering flag checked) stl seems to be recentered nevertheless...
Re: import stl
Post by coppelia » 30 Apr 2013, 10:16
We just tested it here, and it works fine: try to drag a shape into the scene, move it to one corner of the floor, export it as STL, then re-import it again while leaving the recenter flag unchecked: the shape is not centered.
markusi
Re: import stl
Post by markusi » 30 Apr 2013, 12:12
I tested it slightly different.
I saved a .stl (in Solidworks) in a very special coordinate frame. Then I load it into vrep. in vrep it seems the internally used coordinate frame is not where it was in the CAD program (what would be useful especially for sepereate files in an assembly...). It seems vrep recenters those .stls...
Re: import stl
Post by coppelia » 30 Apr 2013, 12:29
I see what you mean now.
The recenter flag recenters the whole imported data in the middle of the scene (and above the ground level). But shapes in V-REP have their reference frame always centered. You can attach a dummy to the shape that indicates the original reference frame of the shape.
Not sure yet anymore how the STL works, but shouldn't the original reference frame of the mesh (i.e. the frame of the mesh in Solidworks for instance) be located at (0,0,0) when importing that mesh? Then simply add a dummy to the scene (it will be at (0,0,0) by default), then attach it to the shape.
