Hello, I'm having difficulties to make the remoteApi work in Matlab. I'm running matlab 2011 32 bits on a machine with win7 64 bits. When I run vrep=remApi('remoteApi') i'm getting the following error:
??? Error using ==> loadlibrary at 441
There was an error loading the library "remoteApi"
The specified module could not be found.
Error in ==> remApi>remApi.remApi at 594
loadlibrary(obj.libName,@remoteApiProto);
Caused by:
Error using ==> loaddefinedlibrary
this means that the remote API library could not be found. Make sure you have the items indicated here in the folder of your Matlab program (or make sure that Matlab can find them). Also, since you are running Matlab 32 bits, make sure to use the 32 bit version of the library (e.g. remoteApi.dll (or similar depending on your platform))
Thaank you very much. Although I had set the current folder to \programming\remoteApiBindings\matlab I needed to set the folder in the Matlab path as well.
