serial communication issue in windows 10
kanishka89
Post by kanishka89 » 11 Aug 2015, 07:22
i was using v-rep on windows 8.1 for more than 6 months and i was able to communicate with an arduino without any hassle. but after upgrading to windows 10 the read values from the serial stream are not available in the stored variable.
here is the code that i use,
countReadChar=simSerialCheck(ardd)
		  if (countReadChar>0) then
			 readDD = simSerialRead(ardd,10,false,'/n',0)
			simSerialSend(ardd,'abc')
				print(countReadChar)
				print(readDD)
Re: serial communication issue in windows 10
Post by coppelia » 11 Aug 2015, 08:50
could you successfully open the port, are there any error codes or messages in the console window?
kanishka89
Post by kanishka89 » 11 Aug 2015, 11:05
yes the port was successfully opened and i monitored the serial buffer also which is reducing as i read the serial port but the variable prints nil on the console
i tested on a another computer with windows 10 today but end up with the same results
Post by coppelia » 12 Aug 2015, 09:58
Ok, we will try to add alternative serial port routines for next release (beta version in 1-2 weeks).
kanishka89
Post by kanishka89 » 12 Aug 2015, 10:37
coppelia wrote:Ok, we will try to add alternative serial port routines for next release (beta version in 1-2 weeks).
hope to see the next release soon.
thanks
Kanishka
dnahar
Post by dnahar » 23 Apr 2016, 02:52
I am facing this issue now. Was this solved? How do i work with this..
Thanks,
Dixit
Post by coppelia » 25 Apr 2016, 08:14
In file V-REP/system/usrset.txt, change the value of useAlternateSerialPortRoutines.
