ROS Publisher
hakim
ROS Publisher
Post by hakim »
Hi.
I have a little problem with my simulator:
Lua API call error: [string "SCRIPT Quadricopter"]:83: Topic could not be published. (simExtROS_enablePublisher)
and the Lua script is as follows:
frontCam=simGetObjectHandle('Quadricopter_frontCamera') topicName=simExtROS_enablePublisher('front_cam',1,simros_strmcmd_get_vision_sensor_image,f,-1,'')
and I have another publisher in the same Lua script and it is working just fine
d=simGetObjectHandle('Quadricopter_base')
 topicName1=simExtROS_enablePublisher('drone_pose',1,simros_strmcmd_get_object_pose,d,-1,'')
and another problem with the ros subscriber
Lua API call error: [string "SCRIPT Quadricopter"]:159: One of the function's argument type is not correct. (simSetObjectOrientation)
I've created a subscriber in the lua script as follows:
subscriberID=simExtROS_enableSubscriber('cmd_deplace',1,simros_strmcmd_set_object_pose,d,1,'')
and in order to use the parameters published by my ros node:
if (subscriberID == -1)then
			simSetObjectPosition(targetObj,sim_handle_parent,{0,0,0})
			simSetObjectOrientation(targetObj,sim_handle_parent,{0,0,0})
			simSetObjectPosition(targetObj,sim_handle_parent,{'cmd_deplace.pose.position.x','cmd_deplace.pose.position.y','cmd_deplace.pose.position.z'})
			simSetObjectOrientation(targetObj,sim_handle_parent,{'cmd_deplace.pose.orientation.x','cmd_deplace.pose.orientation.y','cmd_deplace.pose.orientation.z'})
Any help is welcomed
THX
Re: ROS Publisher
Please do not double-post. See your other question answered here.
