Hello. I just downloaded V-REP_PRO_EDU_V3_2_2_64_Linux and I noted there is a new shared object called libv_repExtRos.so. It needs roscore to be executed already otherwise v-rep crashes. For me the workaround was simple: Move it to another directory that v-rep doesn't look for shared objects in it.
However, I am writing this in bug section because not everyone uses ROS with v-rep.
Cheers,
Pouya.
V-REP_PRO_EDU_V3_2_2_64_Linux crashes on start due to ROS
Re: V-REP_PRO_EDU_V3_2_2_64_Linux crashes on start due to RO
Hello Pouya,
thanks for mentioning this. Such crashes linked to Roscore not running at launch, happened in the past, but doesn't happen anymore (normally). Is it possible that you have a special configuration/system?
I just wanted to report I see the same problem. I'm not trying to use ros and don't have it installed but wanted to report I consistently see the .so load failure crash for that plugin.
Interesting. Thanks for mentioning this.
