Vision sensor image not displayed correctly
felix.s
Post by felix.s »
I don't know if this is truly a bug, but if i move my vision sensor i sometimes get pictures like the one below, where a lot of pixels are white when they should not be (should show a normal black/white chessboard).
Then if i turn or move the vision sensor a little bit the picture is correct again.
Does anyone know where the white stripes come from?
I guess this is somehow connected to the value of the near clipping plane in the vision sensor properties.
For the picture shown above I used a value of 1*e-04, but if I increase the near clipping plane to 0.1 the scene is always displayed correctly.
Thanks in advance
Re: Vision sensor image not displayed correctly
Hello Felix,
what you are seeing is sometimes also called Z-fighting. This happens when two surfaces (i.e. triangles) lie very close to each other, or when the Z-Buffer doesn't have enough precision at the given depth.
As you mention it, you can adjust the near/far clipping planes or your vision sensor or camera, or you can increase the distance between the two surfaces that are fighting.
