Segmentation fault while starting V-Rep over X11 with SSH
indraforyou
Post by indraforyou »
Observed Segmentation fault while starting V-Rep over X11 Forwarding using SSH, both host, client running Linux 64bit.
Its an always issue.
Logs:
$ ./vrep.sh
Segmentation fault (core dumped)
Also, not sure if it matters, I am first connected over vpn then using ssh.
Re: Segmentation fault while starting V-Rep over X11 with SS
this is always tricky, did you have a look at this post?
indraforyou
Thanks for the link. I will check it out.
Regards,
Indranil
