ROS Plugin compilation warning
23pointsNorth
Post by 23pointsNorth »
In ./programming/ros_packages/vrep_plugin/src/vrepSubscriber.cpp (also in V3.3.0)
on line 493, there are some forgotten casts that generate some warning during compilation (testing with c++11). The correct line should be:
simFloat command[6] = {(float)vel->linear.x,(float)vel->linear.y,(float)vel->linear.z,(float)vel->angular.x,(float)vel->angular.y,(float)vel->angular.z};
-Daniel
Re: ROS Plugin compilation warning
Thanks Daniel.
In next release there will be a new ROS plugin that will calc almost 1:1 on the ROS C++ API.
