Crash loading with luajit on OS X
ahundt
Post by ahundt » 31 Mar 2016, 05:25
I've tried setting up luajit, building the v_repLua libraries and linking them to luajit as installed by
http://brew.sh/
brew install luajit
I'm using cmake to link and that seems to work fine, then when I run I get a crash in the dylib function that makes the call to lua to load things up.
Re: Crash loading with luajit on OS X
Post by coppelia » 31 Mar 2016, 10:37
yes, we have the same problem on MacOSX, and still don't know where it comes from unfortunately.
What the library is doing, it is simply forwarding the calls either to Lua or Lua JIT. If you make the library link to Lua, then it works fine.
The library is a simple wrapper, so I can't think of what is going wrong, except maybe in the Lua JIT part..
ahundt
Post by ahundt » 16 Apr 2016, 00:46
Perhaps luajit has an issue tracker where this could be reported? That looks to be the case!
http://luajit.org/list.html
seems reporting issues is encouraged: http://luajit.org/status.html
