V-REP crash when loading plugin with OpenCV
marcofe
Post by marcofe »
Hi all,
I wrote a c++ plugin, named DPD, that uses OpenCV libraries inside (highgui, imgproc, gpu, core ... ). However, V.REP cannot load it properly, it falls in segmentation fault when trying to load the plugin:
Simulator launched.
Plugin 'MeshCalc': loading...
Plugin 'Collada': loading...
Plugin 'ConvexDecompose': load failed (could not load). The plugin probably couldn't load dependency libraries. Try 'ldd pluginName.so' for more infos, or simply rebuild the plugin.
Plugin 'CustomUI': loading...
Plugin 'DPD': loading...
Segmentation fault (core dumped)
This is my Makefile:
CFLAGS = -I../include -I/usr/local/include -fPIC -static `pkg-config --cflags opencv`
LIBS = `pkg-config --libs opencv`
OPENCVLIBS = /usr/lib
OS = $(shell uname -s)
ifeq ($(OS), Linux)
	CFLAGS += -D__linux
	EXT = so
	CFLAGS += -D__APPLE__
	EXT = dylib
endif
TARGET = lib/libv_repExtDPD.$(EXT)
all:
	@rm -f lib/*.$(EXT)
	@rm -f ../../libv_repExtDPD.$(EXT)
	@rm -f *.o
	g++ $(CFLAGS) -c v_repExtDPD.cpp -o v_repExtDPD.o
	g++ $(CFLAGS) -c ../common/scriptFunctionData.cpp -o scriptFunctionData.o
	g++ $(CFLAGS) -c ../common/scriptFunctionDataItem.cpp -o scriptFunctionDataItem.o
	g++ $(CFLAGS) -c ../common/v_repLib.cpp -o v_repLib.o
	@mkdir -p lib
	g++ scriptFunctionData.o scriptFunctionDataItem.o v_repExtDPD.o v_repLib.o -o $(TARGET) $(LIBS) -shared -ldl -lpthread
	@tput bold
	@echo 'Copying $(TARGET) in V-REP folder ...'
	@tput sgr0
	@cp $(TARGET) ../../
Typing
 ldd libv_repExtDPD.so
on the terminal, I get the following output:
  linux-vdso.so.1 =>  (0x00007ffce2be8000)
	libopencv_core.so.2.4 => /usr/local/lib/libopencv_core.so.2.4 (0x00007f5184479000)
	libopencv_gpu.so.2.4 => /usr/local/lib/libopencv_gpu.so.2.4 (0x00007f517e247000)
	libopencv_highgui.so.2.4 => /usr/local/lib/libopencv_highgui.so.2.4 (0x00007f517dfb2000)
	libopencv_imgproc.so.2.4 => /usr/local/lib/libopencv_imgproc.so.2.4 (0x00007f517dad6000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f517d8b9000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f517d6b5000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f517d3a3000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f517d0a7000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f517ce90000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f517cad2000)
	libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f517c8bb000)
	libcudart.so.7.0 => /usr/local/cuda/lib64/libcudart.so.7.0 (0x00007f517c65e000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f517c456000)
	libGL.so.1 => /usr/lib/nvidia-346/libGL.so.1 (0x00007f517c0fe000)
	libtbb.so.2 => /usr/lib/libtbb.so.2 (0x00007f517bed1000)
	libopencv_calib3d.so.2.4 => /usr/local/lib/libopencv_calib3d.so.2.4 (0x00007f517bbf4000)
	libopencv_objdetect.so.2.4 => /usr/local/lib/libopencv_objdetect.so.2.4 (0x00007f517b973000)
	libnppc.so.7.0 => /usr/local/cuda/lib64/libnppc.so.7.0 (0x00007f517b70c000)
	libnppi.so.7.0 => /usr/local/cuda/lib64/libnppi.so.7.0 (0x00007f5177179000)
	libnpps.so.7.0 => /usr/local/cuda/lib64/libnpps.so.7.0 (0x00007f51769bc000)
	libcublas.so.7.0 => /usr/local/cuda/lib64/libcublas.so.7.0 (0x00007f51749fa000)
	libcufft.so.7.0 => /usr/local/cuda/lib64/libcufft.so.7.0 (0x00007f5170b42000)
	libjpeg.so.8 => /usr/lib/x86_64-linux-gnu/libjpeg.so.8 (0x00007f51708f2000)
	libpng12.so.0 => /lib/x86_64-linux-gnu/libpng12.so.0 (0x00007f51706ca000)
	libtiff.so.4 => /usr/lib/x86_64-linux-gnu/libtiff.so.4 (0x00007f5170466000)
	libjasper.so.1 => /usr/lib/x86_64-linux-gnu/libjasper.so.1 (0x00007f517020e000)
	libIlmImf.so.6 => /usr/lib/libIlmImf.so.6 (0x00007f516ff4d000)
	libHalf.so.6 => /usr/lib/libHalf.so.6 (0x00007f516fd0a000)
	libgstreamer-0.10.so.0 => /usr/lib/x86_64-linux-gnu/libgstreamer-0.10.so.0 (0x00007f516fa23000)
	libgobject-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 (0x00007f516f7d4000)
	libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f516f4df000)
	libgstvideo-0.10.so.0 => /usr/lib/x86_64-linux-gnu/libgstvideo-0.10.so.0 (0x00007f516f2c3000)
	libgstapp-0.10.so.0 => /usr/lib/x86_64-linux-gnu/libgstapp-0.10.so.0 (0x00007f516f0b7000)
	libgstriff-0.10.so.0 => /usr/lib/x86_64-linux-gnu/libgstriff-0.10.so.0 (0x00007f516eeaa000)
	libgstpbutils-0.10.so.0 => /usr/lib/x86_64-linux-gnu/libgstpbutils-0.10.so.0 (0x00007f516ec87000)
	libdc1394.so.22 => /usr/lib/x86_64-linux-gnu/libdc1394.so.22 (0x00007f516ea14000)
	libv4l1.so.0 => /usr/lib/x86_64-linux-gnu/libv4l1.so.0 (0x00007f516e80e000)
	libv4l2.so.0 => /usr/lib/x86_64-linux-gnu/libv4l2.so.0 (0x00007f516e602000)
	libavcodec.so.53 => /usr/lib/x86_64-linux-gnu/libavcodec.so.53 (0x00007f516d7f0000)
	libavformat.so.53 => /usr/lib/x86_64-linux-gnu/libavformat.so.53 (0x00007f516d4f0000)
	libavutil.so.51 => /usr/lib/x86_64-linux-gnu/libavutil.so.51 (0x00007f516d2d0000)
	libswscale.so.2 => /usr/lib/x86_64-linux-gnu/libswscale.so.2 (0x00007f516d08a000)
	libQtOpenGL.so.4 => /usr/lib/x86_64-linux-gnu/libQtOpenGL.so.4 (0x00007f516cd8c000)
	libQtGui.so.4 => /usr/lib/x86_64-linux-gnu/libQtGui.so.4 (0x00007f516c0be000)
	libQtTest.so.4 => /usr/lib/x86_64-linux-gnu/libQtTest.so.4 (0x00007f516be98000)
	libQtCore.so.4 => /usr/lib/x86_64-linux-gnu/libQtCore.so.4 (0x00007f516b9c6000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f5184bc2000)
	libnvidia-tls.so.346.46 => /usr/lib/nvidia-346/tls/libnvidia-tls.so.346.46 (0x00007f516b7c3000)
	libnvidia-glcore.so.346.46 => /usr/lib/nvidia-346/libnvidia-glcore.so.346.46 (0x00007f5168aea000)
	libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f51687b5000)
	libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f51685a4000)
	libopencv_flann.so.2.4 => /usr/local/lib/libopencv_flann.so.2.4 (0x00007f5168331000)
	libopencv_features2d.so.2.4 => /usr/local/lib/libopencv_features2d.so.2.4 (0x00007f5168084000)
	libImath.so.6 => /usr/lib/libImath.so.6 (0x00007f5167e7e000)
	libIex.so.6 => /usr/lib/libIex.so.6 (0x00007f5167c5f000)
	libIlmThread.so.6 => /usr/lib/libIlmThread.so.6 (0x00007f5167a58000)
	libgmodule-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0 (0x00007f5167854000)
	libxml2.so.2 => /usr/lib/x86_64-linux-gnu/libxml2.so.2 (0x00007f51674f8000)
	libffi.so.6 => /usr/lib/x86_64-linux-gnu/libffi.so.6 (0x00007f51672f0000)
	libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f51670b3000)
	libgstbase-0.10.so.0 => /usr/lib/x86_64-linux-gnu/libgstbase-0.10.so.0 (0x00007f5166e60000)
	liborc-0.4.so.0 => /usr/lib/x86_64-linux-gnu/liborc-0.4.so.0 (0x00007f5166be5000)
	libgstaudio-0.10.so.0 => /usr/lib/x86_64-linux-gnu/libgstaudio-0.10.so.0 (0x00007f51669ae000)
	libgsttag-0.10.so.0 => /usr/lib/x86_64-linux-gnu/libgsttag-0.10.so.0 (0x00007f5166779000)
	libraw1394.so.11 => /usr/lib/x86_64-linux-gnu/libraw1394.so.11 (0x00007f516656a000)
	libusb-1.0.so.0 => /lib/x86_64-linux-gnu/libusb-1.0.so.0 (0x00007f516635b000)
	libv4lconvert.so.0 => /usr/lib/x86_64-linux-gnu/libv4lconvert.so.0 (0x00007f51660e6000)
	libvpx.so.1 => /usr/lib/libvpx.so.1 (0x00007f5165e41000)
	libvorbisenc.so.2 => /usr/lib/x86_64-linux-gnu/libvorbisenc.so.2 (0x00007f5165972000)
	libvorbis.so.0 => /usr/lib/x86_64-linux-gnu/libvorbis.so.0 (0x00007f5165746000)
	libtheoraenc.so.1 => /usr/lib/x86_64-linux-gnu/libtheoraenc.so.1 (0x00007f5165509000)
	libtheoradec.so.1 => /usr/lib/x86_64-linux-gnu/libtheoradec.so.1 (0x00007f51652ee000)
	libspeex.so.1 => /usr/lib/x86_64-linux-gnu/libspeex.so.1 (0x00007f51650d5000)
	libschroedinger-1.0.so.0 => /usr/lib/libschroedinger-1.0.so.0 (0x00007f5164e22000)
	libgsm.so.1 => /usr/lib/libgsm.so.1 (0x00007f5164c14000)
	libva.so.1 => /usr/lib/x86_64-linux-gnu/libva.so.1 (0x00007f51649fe000)
	libbz2.so.1.0 => /lib/x86_64-linux-gnu/libbz2.so.1.0 (0x00007f51647ee000)
	libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f5164551000)
	libXrender.so.1 => /usr/lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f5164347000)
	libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f5164111000)
	libaudio.so.2 => /usr/lib/x86_64-linux-gnu/libaudio.so.2 (0x00007f5163ef9000)
	libSM.so.6 => /usr/lib/x86_64-linux-gnu/libSM.so.6 (0x00007f5163cf1000)
	libICE.so.6 => /usr/lib/x86_64-linux-gnu/libICE.so.6 (0x00007f5163ad7000)
	libXi.so.6 => /usr/lib/x86_64-linux-gnu/libXi.so.6 (0x00007f51638c7000)
	libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f51636a9000)
	libgstinterfaces-0.10.so.0 => /usr/lib/x86_64-linux-gnu/libgstinterfaces-0.10.so.0 (0x00007f5163497000)
	libogg.so.0 => /usr/lib/x86_64-linux-gnu/libogg.so.0 (0x00007f5163290000)
	libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f5163066000)
	libXt.so.6 => /usr/lib/x86_64-linux-gnu/libXt.so.6 (0x00007f5162e00000)
	libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f5162bfd000)
	libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f51629f8000)
	libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f51627f2000)
Can anyone find the reason why the crash occurs, looking at these outputs above?
Thanks in advance.
Re: V-REP crash when loading plugin with OpenCV
the reason for the crash is difficult to say without seeing your code. The crash happens in your plugin v_repStart entry point. Try adding some prints to the console in that routine to see what exactly triggers the crash.
marcofe
Post by marcofe »
Thanks for your answer. Actually, I can't check anything because even a print in the first line of the v_repStart function is not shown when V-REP crashes.
I have not so many code lines in my plugin: I simply defined a OpenCV black image cv::Mat at the beginning of the function v_repMessage, and I tried to show it in the if-branch sim_message_eventcallback_modulehandle. About this code, and considering that I installed Opencv 2.4.11 on my Ubuntu, I observed a weird behaviour that can be summarized as follows:
1. If I simply write down the required OpenCV libraries in the linking instruction of my Makefile (e.g -lopencv_core, -lopencv_highgui), the plugin is properly loaded, and when I run the simulation the black image is shown. However, typing
it is shown that the loaded libraries are related to OpenCV 2.3 (that I never explicitely installed). If I try to link also -lopencv_gpu, the link fails because this lib is not found. This is not good for me because I do need to use the gpu lib.
2. If I specify the path where OpenCV 2.4.11 is supposed to be installed (/usr/local/lib), -lopencv_gpu is found and linked to the target shared library, along with the other 2.4-versioned OpenCV libraries, as verified by ldd command. However, this is the case where the plugin is not loaded and V-REP crashes.
So, apparently the crash seems to be related to the OpenCV version. Could these infos to be helpful to detect the reason of my issue?
Actually just typing
is not correct, since when you start V-REP with
./vrep.sh
the library path is modified. So in order to verify your library in the same context as when V-REP is loaded, type
./libLoadErrorCheck.sh
but first replace the line
ldd "$dirname/libv_rep.so"
with
ldd "$dirname/libv_repExtDPD.so"
in that file.
marcofe
Post by marcofe »
I tried your suggestion, but it didn't give me new hints to find out the origin of the issue. By the way, after other trials, I observed that the problem is given by the CUDA modules of OpenCV: in fact, V-REP does not crash anymore and the plugin is loaded if OpenCV is built without enabling the CUDA support. If I build OpenCV again with CUDA enabled, then the crash occurs.
Do you know if this is a known issue and/or, what could solve that?
It seems to me something is missing at compile/link time, probably a compilation/linking flag. Since even the plugin load operation crashes before being able to execute a single line of code in the plugin...
marcofe
Post by marcofe »
When I used my application outside V-REP I used the same flags and libraries, and the code worked. So I don't think it's a problem of compilation/linking flag missing. Perhaps it could be a problem of V-REP itself with a CUDA-enabled-version of OpenCV. Have you ever tested that?
We have never tested that. I don't know what else could be the reason..
marcofe
Post by marcofe »
I solved my problem. The reason was not related to the CUDA support, but to the QT support. In particular, the version of QT with which OpenCV has been built was different from the version used to build V-REP. Downloading the proper QT version and re-building OpenCV with QT support did the trick.
Thanks for your willingness.
oh right, I completely forgot about that possibility! Thanks for the precision.
