compile V-REP on Ubuntu Xenial
dpas
Post by dpas » 12 Jun 2016, 19:10
Compiling V-REP on Ubuntu Xenial 16.04, i386, Qt5.5.1 stops on make with an error with 'CCollDiistInterface'. Until the function CPageContainer there is no message of error.
I /usr/lib/i386-linux-gnu/qt5/mkspecs/linux-g++ -o pageContainer.o sourceCode/pagesAndViews/pageContainer.cpp
sourceCode/pagesAndViews/pageContainer.cpp: In member function ‘void CPageContainer::renderCurrentPage(bool)’:
sourceCode/pagesAndViews/pageContainer.cpp:891:7: error: ‘CCollDistInterface’ has not been declared
if (CCollDistInterface::initializeFunctionsIfNeeded())
Makefile:20176: recipe for target 'pageContainer.o' failed
make: *** [pageContainer.o] Error 1
what would you advise to check first to pass through this error?
Re: compile V-REP on Ubuntu Xenial
Post by coppelia » 13 Jun 2016, 09:03
you are right, you can replace:
with
CPluginContainer::isMeshPluginAvailable()
dpas
Post by dpas » 13 Jun 2016, 12:04
Thank you. That effectively solves the problem with this function.
