Crash during startup, clean install on Windows 7 machine
squiddon
Post by squiddon » 15 Jul 2016, 11:24
I can't seem to start VREP on my Windows 7 machines (works fine on OSX).
The console log displays:
Using default Lua library.
Then I get a vrep.exe has stopped working popup.
Is there any way of obtaining a trace so I can debug?
Re: Crash during startup, clean install on Windows 7 machine
Post by coppelia » 15 Jul 2016, 11:42
thanks for reporting this. Can you enable a few debug switched at the top of the file system/usrset.txt and show us the output of the console (or debug log file)?
squiddon
Post by squiddon » 15 Jul 2016, 12:32
I've set all switches to true. I still get the same behavior and no debugLog.txt is created.
Post by coppelia » 18 Jul 2016, 08:08
Then it could be that your folder is write protected?! If you keep sendDebugInformationToFile to false, but set all other debug variables to true, what is the console output?
squiddon
Post by squiddon » 27 Jul 2016, 09:02
This is what I get with sendDebugInformationToFile set to false. I'm running cmd in admin mode.
Post by coppelia » 28 Jul 2016, 08:27
Hm, probably an OpenGl issue... Can you try to set debugOpenGl to true (also in system/usrset.txt) and check the output?
