[JAVA] simxgetcollectionhandle method missing
STAIRSTEP - LU
Post by STAIRSTEP - LU » 26 Jul 2016, 22:08
I'm attempting to call simxGetCollectionHandle so that I can use simxGetObjectGroupData and get data from my collection of proximity sensors. However, when I attempt to call the method, it gives me the error that the method doesn't exist. I'm using the remoteApi.dll from VREP 3.3.1 in my src folder in Eclipse.
Re: [JAVA] simxgetcollectionhandle method missing
Post by coppelia » 27 Jul 2016, 08:50
for the Java remote API you need to use remoteApiJava.dll, not remoteApi.dll
STAIRSTEP - LU
Post by STAIRSTEP - LU » 27 Jul 2016, 19:17
I apologize, remoteApiJava.dll is the .dll file that I have installed. I got it in the 64Bit folder.
Post by coppelia » 28 Jul 2016, 08:29
Can you show us the code you are using to call that function? Also, what is the exact error message?
STAIRSTEP - LU
Post by STAIRSTEP - LU » 28 Jul 2016, 18:57
public int getStateTESTER() {
		IntW sensor_handle = new IntW(1);
		int ObjectHandle = Simulation.vrep.simxGetCollectionHandle(Simulation.clientID, "IR_Sensors", sensor_handle,
			remoteApi.simx_opmode_oneshot);
		// Simulation.vrep.simxGetObjectGroupData(clientID, objectType, dataType, handles, intData, floatData, stringData,
		// operationMode);
		return 0;
And it gives the error:
Exception in thread "main" java.lang.Error: Unresolved compilation problem:
The method simxGetCollectionHandle(int, String, IntW, int) is undefined for the type remoteApi
Post by coppelia » 29 Jul 2016, 08:29
We cannot reproduce your error.
Can you try with following simple program:
import coppelia.IntW;
import coppelia.remoteApi;
public class test
    public static void main(String[] args)
        System.out.println("Program started");
        remoteApi vrep = new remoteApi();
        vrep.simxFinish(-1);
        int clientID = vrep.simxStart("127.0.0.1",19997,true,true,5000,5);
        if (clientID!=-1)
            System.out.println("Connected to remote API server");
            IntW collectionHandle = new IntW(-1);
            int ret=vrep.simxGetCollectionHandle(clientID,"myCollection",collectionHandle,vrep.simx_opmode_blocking);
            System.out.format("Function returned: %d, the collection handle is: %d\n",ret,collectionHandle.getValue());
            vrep.simxFinish(clientID);
            System.out.println("Failed connecting to remote API server");
        System.out.println("Program ended");
