problems running V-REP on macOS Sierra
Montana
Post by Montana » 16 Oct 2016, 13:21
I've been trying to use v-rep 3.3.2 on a MacBook Pro with macOS Sierra but it constantly crashes regardless the scene. To verify wether my computer was the problem, I tried on a different MacBook but the result was the same. Below you can find part of the problem report. Regards.
Process: vrep [967]
Path: /Volumes/VOLUME/*/vrep.app/Contents/MacOS/vrep
Identifier: com.coppeliarobotics.vrep
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: vrep [967]
User ID: 501
Date/Time: 2016-10-16 13:15:12.110 +0100
OS Version: Mac OS X 10.12 (16A323)
Report Version: 12
Anonymous UUID: 9EE51557-EB1F-F7DE-551D-08F18E9AC8E7
Time Awake Since Boot: 2100 seconds
System Integrity Protection: enabled
Crashed Thread: 4 Thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0:
__TEXT 000000010fef5000-000000010ff06000 [ 68K] r-x/rwx SM=COW /var/folders/*/vrep.app/Contents/MacOS/vrep
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff96f4e41a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff96f4d867 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff81de88d4 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff81de7d61 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fff81de75b4 CFRunLoopRunSpecific + 420
5 com.apple.HIToolbox 0x00007fff81388f6c RunCurrentEventLoopInMode + 240
6 com.apple.HIToolbox 0x00007fff81388da1 ReceiveNextEventCommon + 432
7 com.apple.HIToolbox 0x00007fff81388bd6 _BlockUntilNextEventMatchingListInModeWithFilter + 71
8 com.apple.AppKit 0x00007fff7fa7f5f5 _DPSNextEvent + 1093
9 com.apple.AppKit 0x00007fff8018f8eb -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1637
10 com.apple.AppKit 0x00007fff7fa73fbd -[NSApplication run] + 926
11 libqcocoa.dylib 0x0000000113ce37fd 0x113cc2000 + 137213
12 org.qt-project.QtCore 0x00000001100f48cd QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 381
13 org.qt-project.QtCore 0x00000001100f778a QCoreApplication::exec() + 346
14 libv_rep.dylib 0x00000001108af677 App::run(void (*)(), void (*)(), void (*)()) + 743
15 libv_rep.dylib 0x000000011072c047 simRunSimulator_internal(char const*, int, void (*)(), void (*)(), void (*)()) + 887
16 com.coppeliarobotics.vrep 0x000000010fef8d2c main + 1644
17 com.coppeliarobotics.vrep 0x000000010fef6fa4 start + 52
Thread 1:
0 libsystem_kernel.dylib 0x00007fff96f564e6 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff9703d7c5 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007fff9703d221 start_wqthread + 13
Thread 2:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff7fbcbe9e _NSEventThread + 205
6 libsystem_pthread.dylib 0x00007fff9703dabb _pthread_body + 180
7 libsystem_pthread.dylib 0x00007fff9703da07 _pthread_start + 286
8 libsystem_pthread.dylib 0x00007fff9703d231 thread_start + 13
Thread 3:
0 libsystem_kernel.dylib 0x00007fff96f5515a __accept + 10
1 libv_repExtRemoteApi.dylib 0x0000000128e44835 CInConnection::connectToClient() + 325
2 libv_repExtRemoteApi.dylib 0x0000000128e512c6 CSimxSocket::_run() + 422
3 libv_repExtRemoteApi.dylib 0x0000000128e51119 CSimxSocket::_staticThreadProc(void*) + 9
4 libsystem_pthread.dylib 0x00007fff9703dabb _pthread_body + 180
5 libsystem_pthread.dylib 0x00007fff9703da07 _pthread_start + 286
6 libsystem_pthread.dylib 0x00007fff9703d231 thread_start + 13
Thread 4 Crashed:: Thread
0 libv_rep.dylib 0x000000011052cc08 VFile::close() + 8
1 libv_rep.dylib 0x0000000110847635 CFileOperations::saveScene(char const*, bool, bool, bool, bool) + 2229
2 libv_rep.dylib 0x00000001108a986b CSimThread::_handleAutoSaveSceneCommand(SSimulationThreadCommand) + 731
3 libv_rep.dylib 0x00000001108a527c CSimThread::_executeSimulationThreadCommand(SSimulationThreadCommand) + 86796
4 libv_rep.dylib 0x000000011088fc8d CSimThread::_handleSimulationThreadCommands() + 525
5 libv_rep.dylib 0x000000011088f94d CSimThread::executeMessages() + 301
6 libv_rep.dylib 0x00000001108adc97 _workThread(void*) + 519
7 libv_rep.dylib 0x000000011052d9a6 Thread::run() + 70
8 org.qt-project.QtCore 0x000000010ff4cb53 0x10ff15000 + 228179
9 libsystem_pthread.dylib 0x00007fff9703dabb _pthread_body + 180
10 libsystem_pthread.dylib 0x00007fff9703da07 _pthread_start + 286
11 libsystem_pthread.dylib 0x00007fff9703d231 thread_start + 13
Thread 5:
Thread 6:
0 libsystem_pthread.dylib 0x00007fff9703d214 start_wqthread + 0
Thread 4 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000012 rcx: 0x0000000000000000 rdx: 0x0000000000166000
rdi: 0x0000000000000000 rsi: 0x0000000113e26f60 rbp: 0x0000700004eb32b0 rsp: 0x0000700004eb32b0
r8: 0x00000000000000a9 r9: 0x00000000000000a4 r10: 0x0000000113e26000 r11: 0x0000000000000000
r12: 0x00000001110f6938 r13: 0x0000000000000002 r14: 0x00007fff9fa9cd88 r15: 0x00007fff9fa9cd88
rip: 0x000000011052cc08 rfl: 0x0000000000010246 cr2: 0x0000000000000000
Logical CPU: 2
Error Code: 0x00000004
Trap Number: 14
Re: problems running V-REP on macOS Sierra
Post by coppelia » 17 Oct 2016, 07:51
thanks for reporting this. Can you try following:
1. in file v_rep.app/Contents/MacOS/system/usrset.txt, set all items in the debug section at the top to true
2. Start V-REP normally
3. After the crash, send us the file v_repApp/Contents/MacOS/debugLog.txt
Montana
Post by Montana » 17 Oct 2016, 09:21
I can't find the file usrset.txt in that folder, these are the files in that path:
defaultContactCallbackScript.txt
defaultCustomizationScript.txt
defaultGeneralCallbackScript.txt
defaultJointCtrlCallbackScript.txt
dfltscn.ttt
dltcscpt.txt
dltmscpt.txt
dlttscpt.txt
sysnfo.ttb
Post by fferri » 18 Oct 2016, 14:40
Hello, I'm running V-REP 3.3.2 rev3 on macOS Sierra, but I don't experience any crash.
Do you perform any operation to trigger the crash? Can you describe the steps to trigger this crash?
Benno93
Post by Benno93 » 19 Oct 2016, 09:30
I have the same problem. I never used V-Rep before but would love to now.
I downloaded different versions but none won't "immediately" crash.
It is not even necessary to do anything to crash it. My scene is totally empty and after about 2 minutes the program crashes.
It also got some problems with loading the models ("Model folder not found") where normally the robots are shown.
Process:               vrep [1285]
Version:               ???
Responsible:           vrep [1285]
User ID:               501
Date/Time:             2016-10-19 10:23:57.465 +0200
Report Version:        12
Anonymous UUID:        3B9CD32E-5624-2AD2-4AB1-6AFD0DAB2735
Time Awake Since Boot: 1300 seconds
Crashed Thread:        3  Thread
With Windows on bootcamp on the same MacBook (Pro Retina Early 2015) I have absolutely no problems to run the program!
Post by coppelia » 19 Oct 2016, 10:47
So, it seems the problem is linked somehow to the autosave functionality. In the case of Montana, it seems also that the file system/usrset.txt is not generated (should be generated automatically if not present). Which makes me think that this could all be linked to a file access problem.
In any case, can you try to manually create that system/usrset.txt file with following content:
// Debugging
alwaysShowConsole = true
debugGuiThreadAndSimThreadSynchronizationActivity = false // will also slow down V-REP
debugGuiThreadAndSimThreadSynchronizationLockFailActivity = false
debugInternalFunctionAccess = false // will also heavily slow down V-REP
debugCApiAccess = false // will also drastically slow down V-REP
debugLuaApiAccess = false // will also slow down V-REP
debugThreadSwitches = false // will also slow down V-REP
debugEasylockActivity = false // will also slow down V-REP
sendDebugInformationToFile = false // if true, debug info is sent to debugLog.txt
// Rendering
idleFps = 8
threadedRenderingDuringSimulation = 0 // recommended to keep 0 (-1=disabled, 0=pre-enabled, 1=enabled).
desiredOpenGlMajor = -1 // recommended to keep -1.
desiredOpenGlMinor = -1 // recommended to keep -1.
offscreenContextType = -1 // recommended to keep -1 (-1=default, 0=Qt offscreen, 1=QGLWidget/QOpenGLWidget visible, 2=QGLWidget/QOpenGLWidget invisible).
fboType = -1 // recommended to keep -1 (-1=default, 0=native, 1=QOpenGLFramebufferObject).
forceFboViaExt = false // recommended to keep false.
vboOperation = -1 // recommended to keep -1 (-1=default, 0=always off, 1=on when available).
vboPersistenceInMs = 5000 // recommended to keep 5000.
oglCompatibilityTweak1 = false // recommended to keep false since it causes small memory leaks.
visionSensorsUseGuiThread_windowed = -1 // recommended to keep -1 (-1=default, 0=GUI when not otherwise possible, 1=always GUI).
visionSensorsUseGuiThread_headless = -1 // recommended to keep -1 (-1=default, 0=GUI when not otherwise possible, 1=always GUI).
useGlFinish = false // recommended to keep false. Graphic card dependent.
useGlFinish_visionSensors = false // recommended to keep false. Graphic card dependent.
vsync = 0 // recommended to keep at 0. Graphic card dependent.
debugOpenGl = false
stereoDist = 0 // 0=no stereo, otherwise the intra occular distance (0.0635 for the human eyes).
highResDisplay = -1 // -1=automatic, 0=disabled, 1=enabled.
noEdgesWhenMouseDownInCameraView = false // if true, rendering is faster during mouse/view interaction
noTexturesWhenMouseDownInCameraView = false // if true, rendering is faster during mouse/view interaction
noCustomUisWhenMouseDownInCameraView = true // if true, rendering is faster during mouse/view interaction
hierarchyRefreshCnt = 3
// Visual
renderingSurfaceVShift = 0
renderingSurfaceVResize = 0
displayWorldRef = true
antialiasing = false
displayBoundingBoxeWhenObjectSelected = true
guiFontSize_Win = 11
guiFontSize_Mac = 10
guiFontSize_Linux = 11
allowTransparentDialogs = false
dialogTransparencyFactor = 0.400000006
statusbarInitiallyVisible = true
modelBrowserInitiallyVisible = true
sceneHierarchyInitiallyVisible = true
scriptEditorFont =  // empty=default.
scriptEditorFontSize = -1 // -1=default.
auxConsoleFont =  // empty=default
auxConsoleFontSize = -1 // -1=default.
mainScriptColor_background = 190,175,175
mainScriptColor_selection = 128,128,255
mainScriptColor_comment = 0,140,0
mainScriptColor_number = 220,0,220
mainScriptColor_string = 255,255,0
mainScriptColor_character = 255,255,0
mainScriptColor_operator = 0,0,0
mainScriptColor_preprocessor = 0,128,128
mainScriptColor_identifier = 64,64,64
mainScriptColor_word = 0,0,255
mainScriptColor_word2 = 152,0,0
mainScriptColor_word3 = 220,80,20
mainScriptColor_word4 = 152,64,0
nonThreadedChildScriptColor_background = 190,190,190
nonThreadedChildScriptColor_selection = 128,128,255
nonThreadedChildScriptColor_comment = 0,140,0
nonThreadedChildScriptColor_number = 220,0,220
nonThreadedChildScriptColor_string = 255,255,0
nonThreadedChildScriptColor_character = 255,255,0
nonThreadedChildScriptColor_operator = 0,0,0
nonThreadedChildScriptColor_preprocessor = 0,128,128
nonThreadedChildScriptColor_identifier = 64,64,64
nonThreadedChildScriptColor_word = 0,0,255
nonThreadedChildScriptColor_word2 = 152,0,0
nonThreadedChildScriptColor_word3 = 220,80,20
nonThreadedChildScriptColor_word4 = 152,64,0
threadedChildScriptColor_background = 180,190,190
threadedChildScriptColor_selection = 128,128,255
threadedChildScriptColor_comment = 0,140,0
threadedChildScriptColor_number = 220,0,220
threadedChildScriptColor_string = 255,255,0
threadedChildScriptColor_character = 255,255,0
threadedChildScriptColor_operator = 0,0,0
threadedChildScriptColor_preprocessor = 0,128,128
threadedChildScriptColor_identifier = 64,64,64
threadedChildScriptColor_word = 0,0,255
threadedChildScriptColor_word2 = 152,0,0
threadedChildScriptColor_word3 = 220,80,20
threadedChildScriptColor_word4 = 152,64,0
jointCallbackScriptColor_background = 190,190,190
jointCallbackScriptColor_selection = 128,128,255
jointCallbackScriptColor_comment = 0,140,0
jointCallbackScriptColor_number = 220,0,220
jointCallbackScriptColor_string = 255,255,0
jointCallbackScriptColor_character = 255,255,0
jointCallbackScriptColor_operator = 0,0,0
jointCallbackScriptColor_preprocessor = 0,128,128
jointCallbackScriptColor_identifier = 64,64,64
jointCallbackScriptColor_word = 0,0,255
jointCallbackScriptColor_word2 = 152,0,0
jointCallbackScriptColor_word3 = 220,80,20
jointCallbackScriptColor_word4 = 152,64,0
contactCallbackScriptColor_background = 190,190,190
contactCallbackScriptColor_selection = 128,128,255
contactCallbackScriptColor_comment = 0,140,0
contactCallbackScriptColor_number = 220,0,220
contactCallbackScriptColor_string = 255,255,0
contactCallbackScriptColor_character = 255,255,0
contactCallbackScriptColor_operator = 0,0,0
contactCallbackScriptColor_preprocessor = 0,128,128
contactCallbackScriptColor_identifier = 64,64,64
contactCallbackScriptColor_word = 0,0,255
contactCallbackScriptColor_word2 = 152,0,0
contactCallbackScriptColor_word3 = 220,80,20
contactCallbackScriptColor_word4 = 152,64,0
generalCallbackScriptColor_background = 190,190,190
generalCallbackScriptColor_selection = 128,128,255
generalCallbackScriptColor_comment = 0,140,0
generalCallbackScriptColor_number = 220,0,220
generalCallbackScriptColor_string = 255,255,0
generalCallbackScriptColor_character = 255,255,0
generalCallbackScriptColor_operator = 0,0,0
generalCallbackScriptColor_preprocessor = 0,128,128
generalCallbackScriptColor_identifier = 64,64,64
generalCallbackScriptColor_word = 0,0,255
generalCallbackScriptColor_word2 = 152,0,0
generalCallbackScriptColor_word3 = 220,80,20
generalCallbackScriptColor_word4 = 152,64,0
customizationScriptColor_background = 150,150,150
customizationScriptColor_selection = 128,128,255
customizationScriptColor_comment = 0,120,0
customizationScriptColor_number = 220,0,220
customizationScriptColor_string = 205,205,0
customizationScriptColor_character = 205,205,0
customizationScriptColor_operator = 0,0,0
customizationScriptColor_preprocessor = 0,128,128
customizationScriptColor_identifier = 70,70,70
customizationScriptColor_word = 0,0,255
customizationScriptColor_word2 = 152,0,0
customizationScriptColor_word3 = 220,80,20
customizationScriptColor_word4 = 152,64,0
addOnScriptColor_background = 240,240,240
addOnScriptColor_selection = 128,128,255
addOnScriptColor_comment = 0,164,0
addOnScriptColor_number = 220,0,220
addOnScriptColor_string = 205,205,0
addOnScriptColor_character = 205,205,0
addOnScriptColor_operator = 0,0,0
addOnScriptColor_preprocessor = 0,128,128
addOnScriptColor_identifier = 100,100,100
addOnScriptColor_word = 0,0,255
addOnScriptColor_word2 = 152,0,0
addOnScriptColor_word3 = 220,80,20
addOnScriptColor_word4 = 152,64,0
// Directories
defaultDirectoryForScenes =  // absolute path, e.g. d:/myScenes (or leave empty for default path)
defaultDirectoryForModels =  // absolute path, e.g. d:/myModels (or leave empty for default path)
defaultDirectoryForCadFiles =  // absolute path, e.g. d:/myCadFiles (or leave empty for default path)
defaultDirectoryForMiscFiles =  // absolute path, e.g. d:/myMiscFiles (or leave empty for default path)
defaultDirectoryForExternalScriptEditor =  // absolute path, e.g. d:/myScriptTempFiles (or leave empty for default path)
defaultDirectoryForRemoteApiFiles =  // absolute path, e.g. d:/myRemoteApiTransfers (or leave empty for default path)
// Serialization
autoSaveDelay = 0 // in minutes. 0 to disable.
doNotWritePersistentData = false
compressFiles = true
saveApproxNormals = true
packIndices = true
fileDialogs = -1 // recommended to keep -1 (-1=default, 0=native dialogs, 1=Qt dialogs).
bulletSerializationBuffer = 10000000
// Undo/Redo
undoRedoEnabled = true
undoRedoOnlyPartialWithCameras = true
undoRedoLevelCount = 16
undoRedoMaxBufferSize = 80000000
timeInMsForUndoRedoTooLongWarning = 200
// Messaging
doNotShowOpenglSettingsMessage = false
doNotShowCrashRecoveryMessage = false
doNotShowUpdateCheckMessage = false
doNotShowSceneSelectionThumbnails = false
doNotShowProgressBars = false
redirectStatusbarMsgToConsoleInHeadlessMode = false
// Compatibility
middleMouseButtonSwitchesModes = false // has only an effect if navigationBackwardCompatibility is true.
navigationBackwardCompatibility = false // recommended to keep false.
colorAdjust_backCompatibility = 1 // recommended to keep 1.0
specificGpuTweak = false
enableOldPathPlanningGui = false
enableOldMotionPlanningGui = false
useAlternateSerialPortRoutines = false
// Floating license
floatingLicenseEnabled = false
floatingLicenseServer = 127.0.0.1
floatingLicensePort = 20249
// Various
mouseWheelZoomFactor = 1
dynamicActivityRange = 1000
objectTranslationStepSize = 0.0249999985
objectRotationStepSize = 5
processorCoreAffinity = 0 // recommended to keep 0 (-1:os default, 0:all threads on same core, m: affinity mask (bit1=core1, bit2=core2, etc.))
freeServerPortStart = 20000
freeServerPortRange = 2000
useExternalScriptEditor = false
externalScriptEditor = c:/Program Files (x86)/Notepad++/notepad++
abortScriptExecutionButton = 2 // in seconds. Zero to disable.
triCountInOBB = 8
removeIdenticalVertices = true
identicalVerticesTolerance = 9.99999975e-005
removeIdenticalTriangles = true
triangleWindingCheck = true
runCustomizationScripts = true
test1 = false // recommended to keep false.
orderHierarchyAlphabetically = false
macChildDialogType = -1 // -1=default.
useExternalLuaLibrary = false // if true, will call all Lua functions via the v_repLua library ('v_repLua.dll', 'libv_repLua.so' or 'libv_repLua.dylib')
raiseErrorWithApiScriptFunctions = true
I have set the variable autoSaveDelay to 0, which effectively disables autosave.
The first few lines in above file also allow you to turn on/off some debugging switches.
Can you tell me if that makes a difference? By the way, you both have V-REP 3.3.2 rev3?
Benno93
Post by Benno93 » 19 Oct 2016, 11:21
Hi Coppelia,
it seems to work now!
Thanks a lot!
But it still doesn't show the robot models.
On the left (Model browser) there is a folder icon with the "name" "Model founder not found". (see in the picture)
But when I am opening a standard scene from the "scenes" folder with robots inside, there is no problem and the robots are there.
BTW I am using "V-REP PRO EDU V3.3.2 rev3"
For everyone having problems to find the right directory:
1) right-click on vrep (application icon you use to start the application)
2) show package contents (or how it is named in english :D)
3)
4) create the usrset.txt with the content provided by Coppelia in the last post
// Debugging
// Rendering
idleFps = 8
debugOpenGl = false
// Visual
// Directories
// Serialization
packIndices = true
// Undo/Redo
// Messaging
// Compatibility
// Floating license
// Various
triCountInOBB = 8
Benno93
Post by Benno93 » 20 Oct 2016, 08:34
Hi Coppelia,
what could be the reason why the model folder is missing?
Do you know how to fix it?
Post by coppelia » 20 Oct 2016, 09:03
I will contact you with a slightly adjusted program version for testing..
Post by coppelia » 20 Oct 2016, 13:11
Ok, thanks for helping put the finger on the problem Benno. It seems the problems are linked to files/folders that cannot be accessed because of file attributes that the MacOS appends to files downloaded from the internet. You can strip away those file attributes with:
xattr -c -r *
or even better with
sudo xattr -r -d com.apple.quarantine *
(to only strip away the annoying attributes)
Make sure you run above from the console in the V-REP folder. This made the trick for Benno at least.
On our machines, we also have the same file attributes when downloading something from the internet, but we don't have any crashes, so the problem is also linked to some computer specific settings I guess.
Montana, can you confirm that above solves your problem too?
