V-REP 3.0.4
amattag
Contact:
V-REP 3.0.4
Post by amattag »
I wanted to have a look to the new version of V-REP, but I got the following error message with the libSM and libICE libraries when I try to load V-REP:
/lib/ld-linux.so.2 (0xf7713000)
libSM.so.6 => not found
libICE.so.6 => not found
libnvidia-tls.so.304.88 => /usr/lib32/nvidia-current-updates/tls/libnvidia-tls.so.304.88 (0xf5086000)
I have checked and these libraries are currently installed in /usr/lib and I also copy them in the V-REP working directory.
Kind regards,
Antonio.
Re: V-REP 3.0.4
Hello Antonio,
This is strange because V-REP 3.0.4 is built in the exact same way as V-REP 3.0.3
Are you sure you didn't change anything in the mean time? Could you try to run V-REP 3.0.3 to see if the error appears there too?
amattag
Contact:
Re: V-REP 3.0.4
Post by amattag »
I have found that this problem happens with the 32bits version of V-REP, both the 3.0.3 and 3.0.4.
Obviously, I am using this version because I am working on a 32bits machine.
But I tried the 64bits version of V-REP 3.0.3 and 3.0.4 in the same machine and it loads and runs perfectly well, although the ROS
plugin does not load.
Kind regards,
Antonio.
Re: V-REP 3.0.4
Hello Antonio,
You should always use the version that corresponds to your system, e.g.:
  • 32bit Linux --> 32bit V-REP
  • 64bit Linux --> 64bit V-REP
There are some issues if you try to run 32bit V-REP on a 64bit machine.
On a fresh Ubuntu 12.04 32bit, V-REP 3.0.4 32bit runs fine. Same for a fresh Ubuntu 12.04 64bit and V-REP 3.0.4 64bit.
The ROS plugin will only load if you have installed ROS and roscore is running.
