OMPL Plugin crashes ROS interface
lari.casteluci
Post by lari.casteluci » 28 Sep 2017, 19:31
I was trying to use OMPL toguether with Ros Interface. However, when the OMPL tries to find a solution to RRT Connect and is unable to, communication to ros interface crashes and i am unable to communicate any further to ROS. Do you suggest any alternatives so I am able to keep using Motion Planning?
Re: OMPL Plugin crashes ROS interface
Post by fferri » 16 Oct 2017, 09:50
Do you have a reproducible testcase?
lari.casteluci
Post by lari.casteluci » 03 Nov 2017, 15:52
Actually, with further testing (i'm not using OMPL anymore) the communication continues to crash. I've looked in the code a bit, and the problem seems to be with the simSetJointTargetPosition() function. Here is a drive link to my project with all required files, please look first at the READ ME.txt, there is some explanation in there.
https://drive.google.com/drive/u/0/fold ... l95cFVDZnM
Thanks!
Post by coppelia » 07 Nov 2017, 09:14
Can you produce a minimalistic scene that reproduces the crash? A complex project is very difficult/time consuming to debug..
