Segfault on start-up in Ubuntu 18.04
Posted: 24 Apr 2018, 14:16
by petrc
I moved from Ubuntu 16.04 to Ubuntu 18.04 and try to run V-REP 3.5. It crashes with the following output:
Error: signal 11:
libv_rep.so(_Z11_segHandleri+0x28)[0x7f5e989400c8]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f5e9ca6af20]
Using backtrace in gdb I obtained the following result:
#0  0x0000000000000000 in  ()
#1  0x00007ffff11cc19f in QOpenGLContext::makeCurrent(QSurface*) () at ./libQt5Gui.so.5
#2  0x00007ffff2060cf2 in QGLContext::makeCurrent() () at ./libQt5OpenGL.so.5
#3  0x00007ffff30df4df in CMainWindow::CMainWindow() () at ./libv_rep.so
#4  0x00007ffff2db5ea4 in App::createMainWindow() () at ./libv_rep.so
#5  0x00007ffff2c27725 in simRunSimulator_internal(char const*, int, void (*)(), void (*)(), void (*)()) () at ./libv_rep.so
#6  0x00000000004020f2 in main ()
So, it seems that the program is wrongly setting the OpenGL canvas.
I tried to change the provided libQt5 and liblua for the system ones, but with no success.
I searched this forum and found: Weird segfault in liblua (v.3.5.0) which is somehow similar to problems that I am experiencing and might be related.
Note, in headless mode, the program starts correctly.
Finally, I tried to revert back to the V-REP 3.4 and it works.
Re: Segfault on start-up in Ubuntu 18.04
Posted: 26 Apr 2018, 08:01
Ubuntu 18.04 was not tested yet, since the official release date of Ubuntu 18.04 is today.
It will probably only be supported next time we make a V-REP release. Probably by compiling V-REP with a newer version of Qt, you might get rid of the crash.
Posted: 24 May 2018, 22:01
by ariyayi
I have same error for running v-rep 3.5.0 on ubuntu 18.04. Is it possible to fix it or must wait for newer v-rep version ?
Posted: 05 Sep 2018, 19:24
by fabro
Dear all,
I've had the same problem with Ubuntu 18.04. Today I've tried to install a few packages on a "new" installation, and somehow managed to get V-REP working!
The packages I installed were:
- sudo apt-get install libboost-all-dev
(surely people have installed it already, so this should not be the problem!)
- sudo apt-get install lua5.1
- sudo apt-get install liblua5.1-0
- sudo apt-get install liblua5.1-0-dev
(maybe this could be a problem, the "default" lua in Ubuntu 18.04 appears to be 5.2 or 5.3......)
- sudo apt install qtcreator
- sudo apt-get install qt5-default
(maybe this could help....but maybe not....)
QScintilla 2.10.7 from: https://www.riverbankcomputing.com/soft ... a/download
After download and expand, the commands necessary were:
- qmake
- make
- sudo make install
(so I've had to install first qmake, part of qtcreator and qt5: see above!)
After that, vrep started to work!!!! Hope you enjoy!
Best regards, Joao Fabro
Posted: 05 Sep 2018, 22:40
by fferri
You need to install also libqt5serialport5-dev which is not pulled in by qt5-default.
See also this issue https://github.com/voidlinux/void-packages/issues/5254 for fixing additional build errors (namely: error stdlib.h: no such file or directory) caused by gcc 6 + qmake
