Vrep crashing with "Error: signal 11, libv_rep.so" after running for a few minutes on 16.04
Posted: 09 Jul 2018, 18:02
by shantanu
Vrep 3.5.0 was running perfectly fine on ubuntu 16.04 till some time back. Since the last few days it is crashing and giving the following error after running for a few minutes:
Error: signal 11:
/home/shantanu/VREP/V-REP_PRO_EDU_V3_5_0_Linux/libv_rep.so(_Z11_segHandleri+0x28)[0x7f6e88ab90c8]
/lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f6e8cb394b0]
/usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x22ad63)[0x7f6e633afd63]
/usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0xb854e)[0x7f6e6323d54e]
/usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0xa2330)[0x7f6e63227330]
/usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0xb49d6)[0x7f6e632399d6]
/home/shantanu/VREP/V-REP_PRO_EDU_V3_5_0_Linux/libv_rep.so(_ZN3ogl23drawBitmapTextIntoSceneEfffRKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x6f)[0x7f6e88cb24ff]
/home/shantanu/VREP/V-REP_PRO_EDU_V3_5_0_Linux/libv_rep.so(_ZN7CCamera12_drawOverlayEbbbPiP6CSView+0x64a)[0x7f6e8894bd2a]
/home/shantanu/VREP/V-REP_PRO_EDU_V3_5_0_Linux/libv_rep.so(_ZN7CCamera6lookInEPiP6CSViewbb+0xe22)[0x7f6e8894d702]
/home/shantanu/VREP/V-REP_PRO_EDU_V3_5_0_Linux/libv_rep.so(_Z11displayViewP6CSViewP9C3DObjectibbb+0x12e)[0x7f6e88c8348e]
QMutex: destroying locked mutex
Help appreciated.
Thank you
Re: Vrep crashing with "Error: signal 11, libv_rep.so" after running for a few minutes on 16.04
Posted: 10 Jul 2018, 08:00
did you maybe update a driver (e.g. graphics driver?)
Does it still crash if you uncheck Display world reference in the user settings?
Posted: 03 Aug 2018, 23:18
by shantanu
Sorry for the late reply.
I did not update the drivers.
Yes I get the same error and crash after I uncheck the Display world reference in the user settings.
Is there any other settings I can try changing ?
Thank you
