I am new to v-rep as a tool being used for a robotics class. I originally downloaded, extracted and ran v-rep 3.50 rev 4 on an iMac using Sierra. I was able to load scenes, run simulations and see all the robot models. That was about 3 weeks ago. I ran it a couple of more times early on but stopped running it until a day or so ago.
I got an error message that said the following:
The model folder was not found. If the model folder is present in the V-REP folder, then it might be that your system has automatically added attributes to all V-REP files, causing problems. Try running from a terminal
sudo xattr -r -d com.apple.quarantine *
in the V-REP folder to strip away those attributes, otherwise you might experiences strange behaviours and crashes.
I did this and no change. I joined this forum and started searching for solutions. I found a few threads and went thru the suggestions presented and still no luck. I removed the software, reinstalled at the desktop and ran into the same issue.That is where I am at. I can load scenes and models but the dropdown in the file open dialog gives default file locations as being in /private/var/folders/95/ and what looks like windows objects designators. I tried without success to change the default location for folders to the correct location (???) inside the usrset.txt file which I also manually created from the information inside some of the thread. Again it continues to point to the private locations.
And of course this is now happening when I actually have tasks I need to do with the software for classes. I would greatly appreciate any help anyone might give me to get this fixed. Being a procrastinator I see the due wire approaching rapidly.
Thanks again,
joeb
Model folder not found on iMac
Re: Model folder not found on iMac
If the app's default dir shows as /provate/var/folders/... it means the app is running in App Translocation.
From https://lapcatsoftware.com/articles/app ... ation.html:
So, it is very likely that some error occurred and you didn't remove the quarantine attribute.Under what circumstances does App Translocation occur? First, the app must have a com.apple.quarantine extended attribute. If you delete the quarantine xattr, then App Translocation does not occur, and the app will launch from where it was unarchived, like normal.
