OMPL reports solved paths that are incorrect
JBaxter
Post by JBaxter »
Hello!
I am trying to use V-REP's OMPL to motion plan for a robot. I am finding that simOMPL.solve() returns true despite the "solution" returned by simOMPL.getPath() not reaching the goal state. I don't know what is going wrong, as far as I can tell everything I am doing is correct.
I have an example scene file here:
https://drive.google.com/file/d/1nr9Q3_ ... sp=sharing
I am using OSX and the EDU version of V-REP 3.5.0 rev 4.
Thank you very much for your time!
nex
Re: OMPL reports solved paths that are incorrect
Post by nex »
The solution returned by OMPL may be an approximate solution (which is supposed to be still better than nothing).
https://ompl.kavrakilab.org/classompl_1_1base_1_1ProblemDefinition.html wrote:
bool hasSolution() const
Returns true if a solution path has been found (could be approximate)
bool hasExactSolution() const
Returns true if an exact solution path has been found. Specifically returns hasSolution && !hasApproximateSolution()
bool hasApproximateSolution() const
Return true if the top found solution is approximate (does not actually reach the desired goal, but hopefully is closer to it)
