Uli_v
Post
by Uli_v » 05 Apr 2019, 21:38
Any idea where I would need to look at to fix the problem? Is there a threading issue? Is it the remoteAPI?
It seems to happen only if I run several instances of V-REP with several instances of remote API clients (python).
I am running V3.5.0.
*** buffer overflow detected ***: /home/uli/Software/V-REP/vrep terminated
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7fdb2206f7e5]
/lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x5c)[0x7fdb2211115c]
/lib/x86_64-linux-gnu/libc.so.6(+0x117160)[0x7fdb2210f160]
/lib/x86_64-linux-gnu/libc.so.6(+0x1190a7)[0x7fdb221110a7]
/home/uli/Software/V-REP/libv_repExtRemoteApi.so(_ZN13CInConnection15connectToClientEv+0x16b)[0x7fdae558debb]
/home/uli/Software/V-REP/libv_repExtRemoteApi.so(_ZN11CSimxSocket4_runEv+0x111)[0x7fdae5599721]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba)[0x7fdb21ad96ba]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d)[0x7fdb220ff41d]
======= Memory map: ========
./vrep.sh: line 33: 20704 Aborted (core dumped) "$dirname/$appname" "${PARAMETERS[@]}"
Jendker
Post
by Jendker » 06 Apr 2019, 13:39
VRep V3.6.1 is out, try this one :)
- Site Admin
Post
by coppelia » 09 Apr 2019, 13:18
This issue is probably the same as
this one. And it is not yet resolved...
Post
by fferri » 12 Apr 2019, 09:19
Hi Uli_v,
I'm trying to replicate the crash to no avail. Can you try to compile the plugin in debug mode and have it crashing within the debugger to see exactly at which line is crashing?
Post
by fferri » 12 Apr 2019, 14:19
I'm using that example, but I only see V-REP instances increasing in memory usage.
Does it crash because it goes out of memory?
agsdyson
Post
by agsdyson » 12 Apr 2019, 14:24
I don't run out of memory, but after 1600 seconds I cannot connect to the remote API client. I last ran this on v3.6.1 rev2 so things might be different now.
- Site Admin
Post
by coppelia » 16 Apr 2019, 08:31
Can you try following?
In the V-REP folder, you'll find a file named
remoteApiConnections.txt. In there, append following line:
Let me know if that works.
- Site Admin
Post
by coppelia » 18 Apr 2019, 14:23
I have uploaded a new version of the legacy remote API plugin
here. Can you try with that one? Make sure to set value of
useAlternateSocketRoutines to
false again in file
Uli_v
Post
by Uli_v » 25 Jun 2019, 16:56
fferri wrote: ↑12 Apr 2019, 09:19
Hi Uli_v,
How do I compile the plugin in debug mode? I can run my code in debug mode, but it might take some time until it crashes.
