CoppeliaSim crashes when using the distance calculation module
mthor13
Contact:
Post by mthor13 » 12 Dec 2019, 10:07
Dear CoppeliaSim,
First of all thanks for the new and fantastic update to CoppeliaSim!
I am, unfortunately, experiencing a problem with the new update whenever I try to use the distance calculation module.
After starting the simulation with an active distance object, it instantly crashes with the following error code:
/home/mat/vrep_workers/VREP1/coppeliaSim: symbol lookup error: /home/mat/vrep_workers/VREP1/libsimExtGeometric.so: undefined symbol: _ZN10CCalcUtils36isApproxDistanceSmaller_box_tri_fastERK10C4X4MatrixRK8C3VectorS5_S5_S5_Rf
Do you know of any solution for this?
Best Regards,
Mathias Thor
Re: CoppeliaSim crashes when using the distance calculation module
Post by fferri » 12 Dec 2019, 13:20
Does this happen with the scene scenes/minimumDistanceCalculationDemo.ttt?
mthor13
Contact:
Post by mthor13 » 12 Dec 2019, 14:11
No, it does not happen with that scene.
But if I make a simple scene with only two primitives and create a distance object for them, then it crashes right away.
Like to scene: https://drive.google.com/file/d/17UdkzP ... sp=sharing
Addition: If I add a sphere primitive to the minimumDistanceCalculationDemo scene then it cashes whenever calculating the distance to the shape object (not when calculating to the dummy)
Post by fferri » 12 Dec 2019, 14:30
mthor13 wrote:
12 Dec 2019, 14:11
Not crashing here (CoppeliaSim 4.0.0rev1 on macOS). But I don't have the vortex engine, so I changed that to Bullet 2.78. Does it make a difference?
mthor13
Contact:
Post by mthor13 » 12 Dec 2019, 14:34
Hi fferri,
Thanks for checking - it also crashes on me with the bullet 2.78.
For the record, I am running:
- Ubuntu 18.04.3 LTS
- CoppeliaSim Edu V4.0.0. (rev. 1)
Post by coppelia » 13 Dec 2019, 00:16
Hello Mathias,
yes, I can confirm that there is a bug. We'll look into this asap.
Post by coppelia » 16 Dec 2019, 01:02
Hello again,
the bug was corrected. You can either re-download the whole package, or only the incriminated library:
ubuntu16_04
ubuntu18_04
thanks again for your help
mthor13
Contact:
Post by mthor13 » 16 Dec 2019, 13:47
That was fast - thank you very much!
mthor13
Contact:
Post by mthor13 » 03 Jan 2020, 13:02
Hello again Coppella,
I am once again experiencing problems with the distance calculation module. Your fix worked for a while - but now I get the following error message:
Error: signal 11:
/home/mat/vrep_workers/VREP1/libcoppeliaSim.so(_Z11_segHandleri+0x2b)[0x7f17009bfeab]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f1704911f20]
/home/mat/vrep_workers/VREP1/libsimExtGeometric.so(_ZN10CCalcUtils11getDjb2HashEPKcm+0x10)[0x7f16d2937b50]
/home/mat/vrep_workers/VREP1/libsimExtGeometric.so(_ZN10CObbStructC2EPKfiPKiifi+0x1db)[0x7f16d2957d0b]
/home/mat/vrep_workers/VREP1/libsimExtGeometric.so(_Z15geom_createMeshPKfiPKiiPK8C7Vectorfi+0x1ce)[0x7f16d29366de]
/home/mat/vrep_workers/VREP1/libsimExtGeometric.so(geomPlugin_createMesh+0xbb)[0x7f16d28f1c5b]
/home/mat/vrep_workers/VREP1/libcoppeliaSim.so(_ZN16CPluginContainer21geomPlugin_createMeshEPKfiPKiiPK8C7Vectorfi+0x89)[0x7f1700bc7819]
/home/mat/vrep_workers/VREP1/libcoppeliaSim.so(_ZN10CGeomProxy38initializeCalculationStructureIfNeededEv+0x140)[0x7f17008bce90]
/home/mat/vrep_workers/VREP1/libcoppeliaSim.so(_ZN16CDistanceRoutine31_getShapeShapeDistanceIfSmallerEP6CShapeS1_RfPfPiS4_bb+0xc8)[0x7f17007f3358]
/home/mat/vrep_workers/VREP1/libcoppeliaSim.so(_ZN16CDistanceRoutine32_getObjectPairsDistanceIfSmallerERKSt6vectorIP9C3DObjectSaIS2_EERfPfPiS9_bb+0x127)[0x7f17007f64d7]
QObject::~QObject: Timers cannot be stopped from another thread
I recently redownloaded coppeliaSim and also updated some packages in my Linux system (but not something that would expect to crash the distance calculation module). Do you know what could cause this error?
Post by coppelia » 06 Jan 2020, 09:35
Ooops, you are right Mathias!
you can download the library or the whole package again, it should now be fixed. Once for all hopefully ;)
