Proximity sensor incorrect detected points in CoppeliaSim
Posted: 30 Dec 2019, 11:12
Hi!
I have detected an inconsistency in proximity sensor measurements in the brand new CoppeliaSim (4.0.0 rev. 1) compared to V-REP. I have run a simulation that works fine with the latest version of V-REP (3.6.2) in CoppeliaSim and I am getting divergent readings in some cases.
The setup of the test case to reproduce the issue is the following. I place a Pioneer_p3dx robot in the middle of a 1-meter wide corridor with two parallel side walls made from cuboids. The detected points for those sensors that provide valid readings (detectState is True), are listed below for both simulators:
V-REP (Correct values)
CoppeliaSim (Wrong readings for sensors 1, 2, 15 and 16)
Apparently the issue is only present on the left sensors of the robot, which makes me think that the performance improvements introduced in proximity sensor handling broke something. My guess is that the problem has to do with the base change from the robot's reference frame to sensor coordinates.
In case it has something to do or is of any help, I am running the simulator in macOS using the Python Remote API. The first sensor value read uses simxReadProximitySensor in streaming mode and the subsequent in buffer mode. However, with blocking I get the same results shown above.
Thanks in advance for your assistance!
ultrasonicSensor1 = [3.1441450119018555e-05, 4.982848622603342e-05, 0.3612610697746277]
ultrasonicSensor2 = [0.10018845647573471, 8.103251457214355e-05, 0.40471550822257996]
ultrasonicSensor7 = [-0.10175387561321259, -8.227117359638214e-05, 0.4110390841960907]
ultrasonicSensor8 = [3.156896127620712e-05, -4.9985104851657525e-05, 0.36239516735076904]
ultrasonicSensor9 = [3.086135984631255e-05, -4.999287557438947e-05, 0.362407386302948]
ultrasonicSensor10 = [0.10178583860397339, -8.78119608387351e-05, 0.4111681878566742]
ultrasonicSensor15 = [-0.10145333409309387, 8.26176255941391e-05, 0.40982508659362793]
ultrasonicSensor16 = [3.178436600137502e-05, 4.982828613719903e-05, 0.36124250292778015]
ultrasonicSensor1 = [5.331297870725393e-05, 8.431146125076339e-05, 0.6112610101699829]
ultrasonicSensor2 = [0.16708533465862274, 0.00013599544763565063, 0.6749482154846191]
ultrasonicSensor7 = [-0.10175386071205139, -8.243322372436523e-05, 0.4110390543937683]
ultrasonicSensor8 = [3.158394247293472e-05, -4.989875014871359e-05, 0.36239519715309143]
ultrasonicSensor9 = [3.0899773264536634e-05, -4.9993097491096705e-05, 0.3624073565006256]
ultrasonicSensor10 = [0.1017858237028122, -8.775293827056885e-05, 0.4111681580543518]
ultrasonicSensor15 = [-0.16834445297718048, 0.0001361500471830368, 0.6800345778465271]
ultrasonicSensor16 = [5.369991413317621e-05, 8.431158494204283e-05, 0.6112424731254578]
