URDF Import: handle multiple <visual> tags
Gregwar
Post by Gregwar »
I am currently trying to export URDF from a custom software to V-REP, and I would like to be able to export links with multiple colored meshes.
However, as specified here: http://wiki.ros.org/urdf/XML/link , a <link> could ba able to contains multiple <visual> tags, that should be handy for this kind of case. Would it be feasible?
I am currently using fixed-jointed links to do this, the robot tree looks really ugly and overkill
Thanks for your work!
Re: URDF Import: handle multiple <visual> tags
the URDF plugin project files are located in programming/v_repExtUrdf. You could try to modify the code, then recompile the plugin.
Gregwar
Post by Gregwar »
Ok
Will my workaround works with dynamics?
Gregwar
Post by Gregwar »
I've changed the code to handle that.
I've changed link.h, link.cpp & robot.cpp. The strategy is to store the visual elements in a vector and merge it using simGroupShapes if there is multiple tags.
You can have a look at the code+example here: http://gregwar.com/multiple-visuals.tgz
I don't know wether it works good when merged with collisions when link.cpp:435 condition is true
Is there a cleanier way to propose this commit? (Using PR or versionning system)
Gregwar
Post by Gregwar »
My changes are currently bugging with collisions, I am fixing that
peci1
Post by peci1 »
I have fixed it (or at least I think so :) ).
I also added support for multiple <collision> elements, since I use them in my models.
The needed patch is available at https://github.com/peci1/v_repExtUrdf/c ... ster.patch
Coppelia, feel free to integrate these changes into the codebase, I think it'd be of some use for users switching from Gazebo.
Thanks a lot Martin,
your modifications have been integrated.
