Kinect simulation
amattag
Contact:
Kinect simulation
Post by amattag » 24 Jul 2013, 16:39
Is there a way to perform a 3D simulation of the Kinect sensor y V-REP?
Kind regards,
Antonio
Re: Kinect simulation
Post by coppelia » 24 Jul 2013, 17:06
Hello Antonio,
There are 3 Kinect models in current V-REP release:
  • Models/other/interface to kinect: allows you to connect to a real kinect and retrieve skeleton data. That model is currenlly only operational on Windows.
  • Models/components/sensors/kinect: simulates a kinect and visualizes its depth map that can be accessed
  • Models/components/sensors/kinect - closest point calculation: simulates a kinect and calculates the point in 3D of the closest feature (meant as an example)
dioxide91
Post by dioxide91 » 29 Aug 2013, 00:23
I'm new working with V-rep and im going to do a project with kinect using V-REP.
I have already install OpenNI drivers and follow the steps that shows in V-rep when we try to do something with Kinect, but still have an error ocurring:
Unable to locate the entry point of the procedure _glutCreateWindowWithExit on DLL(dynamic-link library) glut32.dll
If anyone knows how to solve it or can give me a few tips how to use the kinect with V-REP it will be gratefull
Post by coppelia » 29 Aug 2013, 00:38
You are probably using an old version of the glut32.dll library. Or maybe a strange flavor of it? Can you try with other versions?
dioxide91
Post by dioxide91 » 29 Aug 2013, 11:18
hello,
I download a recent version and works! thank you :)
Is there any tutorial or something to help programmig V-REP using kinect?
Post by coppelia » 29 Aug 2013, 21:30
There is no tutorial on this yet.
nicolittabl
Post by nicolittabl » 03 Aug 2015, 11:12
HELLO,
i have the same prob, could you please recommend the appropriate Openni version ?
Cheers!
N.
ahundt
Post by ahundt » 05 Aug 2015, 16:48
Is the Xbox One Kinect v2/ Kinectv2 for windows also possible to simulate?
Post by coppelia » 06 Aug 2015, 08:33
you can also simulate that Kinect, you will have to slightly adapt/adjust the existing kinect model.
For connection to the real Kinect, you will need to write a client/server application that connects to V-REP. Have a look at the sample located in programming/windowsOnlyProjects/kinectServer. If a ROS package is available for the Kinect, this would be much easier.
venu
Post by venu » 15 Jul 2016, 11:44
Is it possible to connect a real Kinect to V-Rep in linux?
