Kinect simulation
Re: Kinect simulation
Post by coppelia » 18 Jul 2016, 08:06
yes, you can do this in various ways. The easiest would probably to do this via ROS. Otherwise you will have to write an application that connects and reads the Kinect, and sends the data to V-REP via different means.
GodANU
Post by GodANU » 07 Oct 2016, 22:35
coppelia wrote:you can also simulate that Kinect, you will have to slightly adapt/adjust the existing kinect model.
For connection to the real Kinect, you will need to write a client/server application that connects to V-REP. Have a look at the sample located in programming/windowsOnlyProjects/kinectServer. If a ROS package is available for the Kinect, this would be much easier.
Hi there,
Could you be more spesific by saying "to write a client/server app that connects to V-REP". Is there any tutorial about it that you could share with me?
Best Regards,
Post by coppelia » 11 Oct 2016, 08:21
The more specific part of my answer was Have a look at the sample located in programming/windowsOnlyProjects/kinectServer.
