Can force/torque control of joint achieve positive and negative motion during one control loop?
biscuit122
Post by biscuit122 » 05 Nov 2018, 02:46
In this tutorial, I set a sin function to define a joint force control. But it only move in one direction, so if I do not change target velocity, do you have method to move joint in two direction during one control loop? https://github.com/feig122/force_test
Re: Can force/torque control of joint achieve positive and negative motion during one control loop?
Post by coppelia » 07 Nov 2018, 08:02
you can only set the amplitude of the force/torque. The sign is set via the joint target velocity. So set following:
sim.setJointForce(handle,math.abs(f))
if f~=0 then
    sim.setJointTargetVelocity(handle,math.abs(vel)*f/math.abs(f))
biscuit122
Post by biscuit122 » 07 Nov 2018, 20:37
coppelia wrote:
07 Nov 2018, 08:02
if f~=0 then
Thanks for your brilliant tutorial, which helps me a big deal!
