Missing dependencies for ROS?
jorge
Post by jorge »
i'm trying to build the ros plugin (vrep_common, vrep_plugin) in ROS Groovy and Catkin (which apparently is not setup out-of-the-box using the current file structure and xmls in the programming/ros_stacks folder). Anyway, i've managed to modify the build but there seems to be dependencies problems. catkin_make produces:
Base path: /home/muster/catkin_ws
Source space: /home/muster/catkin_ws/src
Build space: /home/muster/catkin_ws/build
Devel space: /home/muster/catkin_ws/devel
Install space: /home/muster/catkin_ws/install
#### Running command: "make cmake_check_build_system" in "/home/muster/catkin_ws/build"
#### Running command: "make -j2 -l2" in "/home/muster/catkin_ws/build"
[ 25%] [ 50%] Building CXX object vrep_plugin/CMakeFiles/v_repExtRos.dir/src/ROS_server.cpp.o
Building CXX object vrep_plugin/CMakeFiles/v_repExtRos.dir/src/vrep_plugin.cpp.o
In file included from /home/muster/catkin_ws/src/vrep_plugin/src/vrep_plugin.cpp:31:0:
/home/muster/catkin_ws/src/vrep_plugin/include/vrep_plugin/ROS_server.h:55:47: fatal error: vrep_common/VisionSensorDepthBuff.h: No such file or directory
compilation terminated.
In file included from /home/muster/catkin_ws/src/vrep_plugin/src/ROS_server.cpp:29:0:
make[2]: *** [vrep_plugin/CMakeFiles/v_repExtRos.dir/src/ROS_server.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [vrep_plugin/CMakeFiles/v_repExtRos.dir/src/vrep_plugin.cpp.o] Error 1
make[1]: *** [vrep_plugin/CMakeFiles/v_repExtRos.dir/all] Error 2
make: *** [all] Error 2
Invoking "make" failed
In the server.cpp and plugin.cpp there are many includes for the vrep_common folder, eg.
#include "vrep_common/VisionSensorDepthBuff.h"
#include "vrep_common/ForceSensorData.h"
#include "vrep_common/ProximitySensorData.h"
#include "vrep_common/VisionSensorData.h"
#include "vrep_common/VrepInfo.h"
#include "vrep_common/ObjectGroupData.h"
// API services:
#include "vrep_common/simRosAddStatusbarMessage.h"
#include "vrep_common/simRosAuxiliaryConsoleClose.h"
which don't seem to be there. Is there a problem or am i doing something wrong? I'm on Ubuntu 12.04, ROS Groove, V-Rep 3.0.5b (and c). Also, i'm trying to produce msgs/LaserScan, for the Hokuyo model, which would be nice to include by default.
jorge
Re: Missing dependencies for ROS?
Post by jorge »
I've turned to rosbuild and it compiles. Thus it is a catking problem. Since catkin is the default make system for ROS (as of groovy), are ther any instuctions to catkinize the v-rep stacks? Or maybe, include it in the next v-rep reliease (together with the Laserscan msg! for pete's sake...)
yes, this is on our todo list (move to ROS Hydro and add a laserscan message), but not yet sure it will make it to next release... any help is always welcome and we'll be more than happy to integrate modifications/recommendations from others ;)
jorge
Post by jorge »
Hi Coppelia,
i've managed to create the Laserscan msg from the ROS api (it publishes correct data, and I can visualize it in rviz). The Hokuyo model also need a minor modding. If you want me to publish (or send you) the mods, please post it (or send me an email).
Best
George
Hi George,
that's great, thanks. Yes, please send us your modifications, we'll try to include them for next release.
