I'm new here and I'm starting a project in v-rep when I have to work with youbot.
I do not have much knowledge of LUA programming and I feel much more comfortable in C/C++.
I've read the V-REP User Manual but I have a question:
Can I control the whole robot only with C language? or do i have to write some things in LUA?
If yes, is possible only through remote api? or is it possible otherwise?
thank you
C/C++ Doubt
Re: C/C++ Doubt
yes, you can program your robot controller only via C/C++, if you wish. In that case, you have 2 possibilities:
- using the remote API, which allows to have your controller run on a different program, different computer, or even on the real robot.
- using a plugin. This allows to have a very fast interaction between the simulation and the controller, and also a synchronous operation between the controller and the simulation. Moreover, a plugin allows to customize the simulator to a great extent.
