I'm not really sure what is external Qt frameworks exactly in the following message I got after running running macdeployqt vrep.app in terminal:
WARNING:
WARNING: Could not find any external Qt frameworks to deploy in "vrep.app"
WARNING: Perhaps macdeployqt was already used on "vrep.app" ?
WARNING: If so, you will need to rebuild "vrep.app" before trying again.
WARNING:
WARNING: "vrep.app/Contents/Resources/qt.conf" already exists, will not overwrite.
WARNING: To make sure the plugins are loaded from the correct location,
WARNING: please make sure qt.conf contains the following lines:
WARNING: [Paths]
WARNING: Plugins = PlugIns
I checked the qt.conf already contains those lines.
So now I'm confused. Do I have to rebuild vrep.app with the new plugins?
Generated SimpleFilter plugin crashed
Re: Generated SimpleFilter plugin crashed
No, that is normal that it generates error messages: macdeployqt was already called on most files of this bundle. But normally it should still have adjusted the new library (even whith the error messages).
From the log using verbose option, I think I understand what you mean, but isn't that the Qt plugins for the V-REP framework itself that get adjusted, such as the image formats, etc(located in vrep.app/PlugIns, not the one located in vrep.app/MacOS)?
I tried to put the new library in the PlugIns folder, and inside the MacOS folder but still no good.
>> macdeployqt vrep.app -verbose=3
Log: Using otool:
Log: inspecting "vrep.app/Contents/MacOS/vrep"
WARNING:
Log:
Log: Deploying plugins from "/Developer/Applications/Qt/plugins"
WARNING:
WARNING: [Paths]
Log: Using otool:
WARNING:
Log:
WARNING:
WARNING: [Paths]
That's right. But at the same time your plugin also depends on Qt, and needs to be adjusted appropriately.
Following worked here:
- Take a fresh copy of V-REP
- paste the newly compiled plugin inside of vrep.app/Contents/MacOS/
- from the command line. call macdeployqt vrep.app. This will generate errors.
- now it should be operational. At least that procedure worked here.
