A* pathfinding
Posted: 12 Jan 2014, 19:49
by Electr0
Does anyone already implement this algorithm in V-REP?
how to make a grid cell for heuristic calculations? and how to make robot believe that he is in one cell of the grid?
Re: A* pathfinding
Posted: 13 Jan 2014, 10:52
you can easily do this, the most important step would be to discretize the world. For that, you have several possibilities, such as:
- by using a vision sensor watching down onto the floor. You can add filter components in order for the vision sensor to produce only black or white pixels (e.g. black=empty, white=occupied). The resolution of your vision sensor will be the size of the grid.
- by using a proximity sensor that you sweep across your terrain in order to sample out empty grid areas.
Re: A* pathfinding
Posted: 13 Jan 2014, 18:46
by Eric
In order to get the grid coordinates based on the robot position (i.e. its Cartesian position), you can also do
xg= math.floor(x/gridSize)
yg= math.floor(y/gridSize)
where xg and yg are the robot s coordinates in grid space, gridSize, the size in meter of each cells, x and y re the Cartesian coordinates of the robot
PS: A sample scene that does that can be downloaded at:
https://dl.dropboxusercontent.com/u/942 ... isplay.ttt
Re: A* pathfinding
Posted: 14 Jan 2014, 01:46
by Electr0
thank you for your answers
but when I open the scene that Eric post, it shows a initial message that I'm not using the latest version of the v-rep and thus parts of the scene will not be displayed.
but I have the latest version, I think, what is happening?
Re: A* pathfinding
Posted: 14 Jan 2014, 12:06
the reason for this is that Eric is using a beta version of next release. But that should still load fine in V-REP 3.0.5 (or even in V-REP 3.0.4, but colors might be slightly wrong in that case).
Re: A* pathfinding
Posted: 14 Jan 2014, 14:30
by Electr0
so the only things that is wrong are the colors?
Re: A* pathfinding
Posted: 14 Jan 2014, 16:36
by Eric
Hi!
I saved the scene with a 3.0.5 in order to prevent the message to show up.
The scene behaves the same way. It consists of a very simple scene where you can move around the youBot robot using its control interface (that appears when you click on the youBot). When the robots moves around, a red plane is moved to the grid where the robot is located, and overlays the the robot s position in grid coordinates.
It shows how to "make robot believe that he is in one cell of the grid", or more exactly transform the robot s Cartesian coordinates into grid coordinates.
The code that does that is in the script attached to the defaultFloor. I hope it helps
Eric
Re: A* pathfinding
Posted: 14 Jan 2014, 21:04
by Electr0
it helps a lot ;)
so from here i can start implement the A* algorithm?
i understand all the theory, but i'm a little bit confused with the code, the first point is to create two vectors to put the values of xg yg and the other to put the xg and yg with the lowest cost (F) right?
Re: A* pathfinding
Posted: 30 May 2019, 22:54
by Jacky
Hi, Dear Eric:
Sorry for bothering sincerely, I have also met same issues for A star algorithm, can you please share the vrep sence if there was possible?
Yours Sincerely
Jack
