Install V-rep Under Ubuntu (tar.gz)
curka
Post by curka »
Hi
How can i install v-rep under Ubuntu?
curka
Re: Install V-rep Under Ubuntu (tar.gz)
Post by curka »
Hi Again!
I unpacked the tar.gz file and in the terminal i wrote this:
cd Letöltések/V-REP_PRO_EDU_V3_0_2_64_Linux
./vrep.sh
and i get a Syntax error: Unterminated quoted string:
:~$ cd Letöltések/V-REP_PRO_EDU_V3_0_2_64_Linux
:~/Letöltések/V-REP_PRO_EDU_V3_0_2_64_Linux$ ./vrep.sh
/home/witcher/Letöltések/V-REP_PRO_EDU_V3_0_2_64_Linux/./vrep: 1: /home/witcher/Letöltések/V-REP_PRO_EDU_V3_0_2_64_Linux/./vrep: Syntax error: Unterminated quoted string
Can you help?
Not sure what problem you have, but it must be Ubuntu-related.. what version are you using?
curka
Post by curka »
Ubuntu 13.04
I tried with the new V-rep version, i also have synstax erros:
:~$ cd Letöltések/V-REP_PRO_EDU_V3_0_5c_64_Linux
:~/Letöltések/V-REP_PRO_EDU_V3_0_5c_64_Linux$ ./vrep.sh
/home/witcher/Letöltések/V-REP_PRO_EDU_V3_0_5c_64_Linux/./vrep: 1: /home/witcher/Letöltések/V-REP_PRO_EDU_V3_0_5c_64_Linux/./vrep: Syntax error: "(" unexpected
you must have a problem with your shell. The script (vrep.sh) that launches V-REP contains basically:
#!/bin/sh
dirname=`dirname $0`
if [ $dirname != "." ]; then
	echo "*****************************************"
	echo "Please launch V-REP from a terminal, from"
	echo "within its folder with ./vrep.sh         "
	sleep 5s
	appname=`basename $0 | sed s,\.sh$,,`
	tmp="${dirname#?}"
	if [ "${dirname%$tmp}" != "/" ]; then
		dirname=$PWD/$dirname
	fi
	LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$dirname
	export LD_LIBRARY_PATH
	$dirname/$appname "$@"
fi
Maybe try to ask in some Ubuntu-specific forums, we never had similar problems.
curka
Post by curka »
I solved the poblem. Ireinstalled the Ubuntu 13.04 and v-rep works well :)
thank you fo your help :)
