simGetVisionSensorxxxx() memory leak
ryt
Post by ryt » 24 Jan 2014, 14:23
Hello
I wrote down a plugin to create a LUA custom function. This function tried to acces vision sensor data using simGetVisionSensorDepthBuffer() and simGetVisionSensorImage(). As I run my plugin in simulation, my memory consumption continuously increased and reached maximum. I did some checking through all line in my code and found out that the leak sources are those two functions. The part of my code is shown below.
float *depth_image, *color_image;
depth_image = simGetVisionSensorDepthBuffer(vision_handler);
color_image = simGetVisionSensorImage(vision_handler);
I have tried to free() those pointer, but it return an exception. Is there any solution for this?
Is it related with the C-return value explanation in API section of simGetVisionSensorImage() --> "The user is in charge of releasing the returned buffer with simReleaseBuffer"?
Re: simGetVisionSensorxxxx() memory leak
Post by coppelia » 24 Jan 2014, 14:46
If I understood you correctly, your cutom Lua function is calling the vision sensor functions via a plugin, in C/C++, right?
The C/C++ version of the simGetVisionSensorDepthBuffer and simGetVisionSensorImage functions require you to destroy the returned buffers via the simReleaseBuffer functions. free, delete or delete[] will not work and leads to possible crashes.
ryt
Post by ryt » 24 Jan 2014, 17:47
OK, but my pointer is float. The simreleasebuffer parse char pointer. It will show error in plugin compiling..
Post by coppelia » 24 Jan 2014, 18:01
You should cast the pointer to (char*)
markusi
Post by markusi » 18 Jul 2018, 15:59
I want to access a vision sensor several times during a simulation.
Therefore I extended the robot lua script to save some Vision Sensor images to the HDD. That works pretty well but memory usage grows over time causing system crashes.
sim.handleVisionSensor(visionsensorHandle)
local img_handle = simIM.readFromVisionSensor(visionsensorHandle)
local imgfilename = "d:\\data\\" .. imagenumber .. ".jpg"
simIM.write(img_handle,imgfilename)
I may face a memory leak problem with simIM (see also https://github.com/CoppeliaRobotics/v_r ... e/issues/1)
I tried to free memory like below:
simIM.destroy(img_handle)
simimhandles = simIM.handles()
for i in pairs(simimhandles) do
simIM.destroy(simimhandles)
but that doesn't help.
Any suggestions ?
Post by coppelia » 20 Jul 2018, 07:34
there was indeed a memory leak in the image plugin. Did you try to recompile the plugin after that?
