Creating a spring
Posted: 12 Feb 2014, 23:12
by smilamc
I have read your posts about using a prismatic joint to create a spring damper system and I am still unclear about how to do that, could you walk me through how you would use a prismatic joint to replicate a 12N/m spring with a rest length of .02 meters.
Re: Creating a spring
Posted: 14 Feb 2014, 10:44
For a spring, you have Hook's law:
F=k*x
where
F is the force of a spring,
k its constant, and
x its displacement (or stretch/compression)
In V-REP, set your joint (let's suppose it's a prismatic joint) into
torque/force mode, the
motor enabled, the
Control loop enabled,
Position control (PID) selected, and
Regulate torque/force selected. You can do all this in the
joint dynamics properties.
In V-REP, with above settings, your joint will exert a force:
F=ctrl*maxForce
where
maxforce is the
max. torque/force item, and
ctrl is a PID control:
ctrl=x*P+integratedErrors*I+(x-previous_x)*D
So, in case of a pure spring:
F=x*P*maxForce
so, k=P*maxForce. In your case, you could pick:
maxForce=12 and
P=1.
Posted: 09 May 2018, 11:24
by s7405570
hi
I tried this methond , and it shows a very strange graph.
The first strange thing is that the fig is supposed to plot a sin wave.
In the mean time, the amplitude descend fast along with time. The descend is bigger when simulation step time is bigger.
I set step time to 0.1ms, and get this fig. The descend is still unacceptable.
Posted: 09 May 2018, 15:31
by s7405570
I've find another way slove this problem.
First disable the prismatic joint motor , we don't need the motor contorl.
Then create a threaded script with the following code:
function sysCall_threadmain()
sim.setThreadAutomaticSwitch(false)
cyhandle=sim.getObjectHandle('Cylinder')
cyhandle0=sim.getObjectHandle('Cylinder0')
initPosition=sim.getObjectPosition(cyhandle,cyhandle0)
k=100
tempPosition=sim.getObjectPosition(cyhandle,cyhandle0)
distance=tempPosition[3]-initPosition[3]
print(distance)
lastforce=distance*k
sim.addForceAndTorque(cyhandle0,{0,0,distance*k},{0,0,0})
sim.switchThread() -- resume in next simulation step
As you can see in the pic, the fig is real sin wave and the descend is very small
cheers!
This script serves as a real spring between the two objects. Here is the result:
