Inverse Kinematics Unstable
mrshifo
Post by mrshifo »
Hello to all,
I'm new with v-rep, I'm trying the inverse kinematics for a mobile robot. I do not understand why it becomes unstable. Can you help me?
http://dropcanvas.com/rsgj0
thanks
andrea
Re: Inverse Kinematics Unstable
Hello Andrea,
2 things:
  • your kinematic chain is wrongly defined. The base of your chain is base_joint, but it should be basetrack (otherwise base_joint won't be involved in IK resolution)
  • the try switching to the Vortex engine. You'll have a stable situation. With the two other engines, you will have to tweak the masses and inertias.
mrshifo
Post by mrshifo »
Thanks for the help,
I already tried to change the mass and inertia is increasing or decreasing but remains unstable you can give me some advice because I want to use BULLET or ODE since vortex stops 20 seconds.
thank you very much
Andrea
mrshifo
Post by mrshifo »
I partially solved tuning the masses and inertia but when I add a piston (like the model excavator) the kinematic chain becomes unstable why ?
http://dropcanvas.com/wh606
thanks
You have several IK problems with your mechanism that you first need to solve:
  • IK_Group1 that is solving the piston IK needs to be executed after the other IK tasks (since it is not the main task)
  • IK_Group1 has the wrong base. IK_Group1 should involve in IK resolution exactly 2 joints, no more.
  • the joint Prismatic_joint_piston1 is in passive mode. That doesn't work with IK
  • you do not need the damped IK_Group0. When something that is supposed to be stable is not stable, then adding damping is a very bad idea, since you are just covering up a larger problem. Damping in IK should only be used when the constraints cannot exactly be satisfied (e.g. target is out of reach, close to a singularity, etc.).
mrshifo
Post by mrshifo »
I'm sorry,
I tried to edit as you said but the base of the piston does not remain centered with the link1. Can you help?
http://dropcanvas.com/nekvi
thanks
