Hello. I'm starting with v-Rep and would like to know if there is a very basic introductory tutorial that talks about how to associate a movement to a robot.
A useful example for me would be how to make/draw in air a circle with the effector of an industrial robot?
Is it possible?
Thank you so much!
Best regards.
Drawing a circle?
Re: Drawing a circle?
you have several ways of doing this. First you need to have that circle trajectory. You could:
Make sure to check the IK tutorial.
- use a revolute joint and attach a dummy to it, then make that revolute joint turn (e.g. from within a child script for instance).
- use a circular path, or any other path
- or simply compute the trajectory coordinates yourself
Thank you so much.
Then, computing the trajectory coordinates for myself, is it possible to simulate another movements? by example a sinusoidal (ie by using a formula or a table values)?
I'm reading the manual., but where should I start to simulate this example? (I do not know if it is a simple example).
Thank you again!
Best regards
Thank you again!
Best regards
absolutely, you can imagine just any trajectory. A good start would be to follow the IK tutorial, then control programmatically the end-effector target position/orientation (i.e. your circle trajectory).
Thank you.
One question about IK Tutorial: I can not see this option, after select all imported shares:
Select all imported shapes and click [Menu bar --> Edit --> Bounding box alignment --> Align selected shapes' coordinate frame with world].
Where can I found it?
Best regards.
Best regards.
The menus have changed slightly. Try with:
[Menu bar --> Edit --> Reorient bounding box --> with reference frame of world]
