Is there a way to import a robot's kinematics from a .dae file? I successfully imported the geometry from collada files, but the import plug-in gives an error stating "Import failed" when using the kinematics file.
Is this a general problem or is it just the files I use?
Thank you very much in advance and best regards,
Daniel
Problem Importing Collada Kinetmatics
Re: Problem Importing Collada Kinetmatics
Hello Daniel,
the Collada plugin currently only imports meshes and transformations. Kinematics and other data are ignored.
Okay, that's sad. Do you have any idea how I could successfully import the kinematics as well? Can I convert my files to another format that V-Rep can successfully read the kinematics from?
Currently, you can only import the kinematics via the URDF plugin.
But you could always write a small add-on that reads a file, then builds the kinematics appropriately.
