Kinematic and Dynamic parameters
Posted: 30 Apr 2014, 03:08
by realjsk
Where to get the kinematic and dynamic parameters of the robots provided in V-Rep (IRB 140, for instance)?
Re: Kinematic and Dynamic parameters
Posted: 30 Apr 2014, 13:24
what parameters are you refering to?
As an example, you can check a shape's dynamic parameters (such as mass, inertia, material, etc.) in the shape dynamic properties. You can also set/get some of those parameters via the API (e.g. simSetShapeMassAndInertia).
Posted: 30 Apr 2014, 14:02
by realjsk
What about the geometric properties of the links/joints (e.g., length, diameter, etc.)? Thanks.
Posted: 30 Apr 2014, 14:27
Posted: 30 Apr 2014, 19:08
by realjsk
Do I have to write a code to get them. Can't I get them through the user interface?
Posted: 30 Apr 2014, 19:40
You can also use the user interface for that of course. You can import, export, create objects, change parameters, etc.
Posted: 01 May 2014, 00:56
by realjsk
You missed my point. What I meant was if I work with any of the manipulators that come with V-REP (say IRB 140, for instance) and I want to know the length of link 1, for example, how can I do that from the user interface? But I finally got it. I just have to see the bounding box under "view/modify geometry". Thanks.
