Calculating distance and printing it
cena
Post by cena » 10 Jul 2014, 10:55
Can anyone tell me what do i have to do if i want to calculate the distance between a moving robot for example the pioneer p3dx and any obstacle around it for example a wall. Also how can i see the value on the simulation ?
I am guessing i need to use proximity sensors or already built in sensors in the robots for example pioneer p3dx has 16 ultrasonic sensors i think. Also what do i need to add in the code ? Please help.
Kind regards
Maruf
Re: Calculating distance and printing it
Post by coppelia » 10 Jul 2014, 21:04
Hello Maruf,
to compute the minimum distance between your robot and the environment, use the distance calculation module. Once you have registered a distance object, you can access it, read it and print the distance from a child script with:
handle=simGetDistanceHandle('myDistanceObjectName')
result,distance=simReadDistance(handle)
print(distance) -- prints the distance to the console
Of course you can do something similar with proximity sensors.
rohanp
Post by rohanp » 14 Feb 2018, 08:48
hello,
so i am trying to obtain similar data and i tried using the above steps as specified. But I am receiving error at the below statement (correct me if i am wrong):
DistHandle = simGetDistanceHandle('FrontLeg') --statement executed during initialization
What I think, the error is due to the use of wrong distanceobject name: 'FrontLeg'
In such a scenario, how to know which is the correct name and whether the name used is a legal name?
Post by coppelia » 15 Feb 2018, 09:09
I see two potential problems:
  • either you have misspelled the object name (it is case sensitive)
  • either you have not understood how object handles are retrieved. Make sure to read this page
Sagar Kalburgi
Post by Sagar Kalburgi » 02 Apr 2018, 05:19
Hey, How do I calculate the distance that my bot has moved and display the distance so that I can use this data for future applications? I'm unable to get it done using simxGetDistanceHandle.
Post by coppelia » 03 Apr 2018, 06:53
You need to give us more information. Where are you trying to get and display the distance? In V-REP or in an external application?
