Measure Joint Velocity
dds
Post by dds » 21 Jul 2014, 23:18
Hi, what is the best way to measure the velocity of a joint?
Snork_svk
Re: Measure Joint Velocity
Post by Snork_svk » 22 Jul 2014, 08:54
Hello
If you want just simply display in the window is the best to use Graph
where to set Joint velocity and select the desired joint and then give it into view Floating
If necessary use in an internal script is required to use regularAPI features: sinGetJointPosition obtained from the difference of rotation of the joint and the sampling frequency you know exactly calculate the speed
the same is true when you want to check in your script, you just have to use remoteAPI function simxGetJointPosition
dds
Post by dds » 22 Jul 2014, 13:41
Hi. What would be the difference with
jointVelocity=simGetObjectFloatParameter(jointHandle,2012)
?? which option is more accurate?
Post by coppelia » 22 Jul 2014, 15:58
both options will result in the same value. Option 2 will do the calculation for you (comparing positions between two successive simulation steps).
